Holley 4160
Holley 4160
I'm using a holley 4160 list #3367 on my 65 L79. Is it correct to connect hose from large port located on the carb base on the driverside to the oil fill tube? Thanks
Yes, although you'll need to install a PCV valve in the line or you'll have a large vacuum leak. On the original Holley 2818 the hose connected to a 90 degree fitting with calibrated orifice to limit flow. Change your oil filler tube to a 66 or 67 style with the boss for the PCV valve.
I am working on an improvement. But heres how it would look using the screw in PCV.Stays snug in the hose. Not too bad, works fine.
http://forums.corvetteforum.com/albu...ictureid=64312
