Holley Carb Rebuild Help
Old 03-01-2011, 11:31 PM
rayvaflav
Support Corvetteforum!
rayvaflav's Avatar
Default Holley Carb Rebuild Help
After rebuilding my original Holley 3367 for my '66 I have discovered that I have no business rebuilding a Holley. That thing just dumps fuel, fouls the plugs and annoys the neighbours. I've readjusted the floats many times, replaced the new power valve with a newer power valve and everytime I bolt it back up, it's the same thing.
Now here is where I need your help: I don't want your help. Or your advice. I just want to pay you to get my Holley right, no cosmetic work and you need to be able to bench run it after it's done, send it back to me so that I can bolt it on and go. I'd try it again myself but I don't wanna buy anymore sparkplugs ! Who on this Forum has this special gift that I don't ?
Ray
Old 03-01-2011, 11:49 PM
54greg
54greg's Avatar
Old 03-02-2011, 12:09 AM
midyearvette
midyearvette's Avatar
send it to "knuckles" ray.....we'll fix it!.....
sent you my address
Old 03-02-2011, 07:01 AM
mscaggs
mscaggs's Avatar
Eric's work is second to none. Pure perfection, period...
http://www.vintagemusclecarparts.com/
Old 03-02-2011, 07:15 AM
6T7L71CPE
6T7L71CPE's Avatar
No surprise here, I think you're WARPED! The Holley body, that is. ;{ )
Old 03-02-2011, 08:36 AM
jbalch
jbalch's Avatar
Eric is very good and I would certainly use his service again.
Old 03-02-2011, 09:25 AM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Larry
Old 03-02-2011, 09:40 AM
wfortune@snet.net
wfortune@snet.net's Avatar
I have had the same issues, ready to tear my hair out.
Will contact eric!
Lt.C
Old 03-02-2011, 09:42 AM
mscaggs
mscaggs's Avatar
Will contact eric!
Lt.C
Eric did my carb a few months ago and it was absolutly perfect. His refinishing is super great too.
Old 03-02-2011, 09:36 PM
Thomas66
Thomas66's Avatar
I just spoke with Eric today. My carb is finished, and ready to return. The many endorsements on the forum convinced me that Eric was the way to go.
Old 03-02-2011, 09:53 PM
P Knopp
P Knopp's Avatar
I went round and round with the same deal, the only thing that worked was putting in a cheap pressure regulator.
Old 03-03-2011, 08:15 AM
mscaggs
mscaggs's Avatar
Let us all know what you think after bolting her on the car okay
Old 03-03-2011, 09:41 AM
Thomas66
Thomas66's Avatar
Will do. It is going to be awhile because I plan on pulling the engine to detail the bay. I can't get started until it gets a little warmer. I only was able to get my garage ceiling insulated before the cold set in and hunting and snowmobiling kept me occupied. The HotDog space heater is still in the box.
Old 03-03-2011, 09:45 AM
mscaggs
mscaggs's Avatar
Good luck on that engine pull. I am just finishing mine up this weekend. Lots of hard work and cost me way more than I thought (old story). The "While I'm at it" will sneak up on you trust me. You will glad when it's done as you will be proud when you pop that hood... Good luck.
Here are a few photos of my project...
http://www.myvintagecorvette.com/engine
This is the almost finished project...
Old 03-04-2011, 01:55 PM
rayvaflav
rayvaflav's Avatar
Thanks for the replies and suggestions fellas, after a lovely conversation I have decided to send the carb to Forum member midyearvette who is currently doing business as "Knuckle's Speed Shop And Scotch Emporium". I am happily expecting ,upon it's return, a nicely sorted carburetor and a bottle of Dewar's (and a midyear console insert to hold it, I've seen the photos ... ).
Ray
Old 03-04-2011, 03:36 PM
midyearvette
Ray
we will have a "carb clinic day" at my house when ray's arrives......dahogan will bring over his 66 L79 and beer
between the two bad carbs, i bet i can build ONE good one
we will use hogan's car for a test bed
i have also heard that carbs are mysteriously damaged in shipment from ohio to oklahoma?? anyone else know of this phenom??......
Old 03-04-2011, 03:56 PM
Jackfit
Jackfit's Avatar
Default send it send it send it
sent you my address
He will just cook some brotts, invite DaHogan and Jim over, drink a lot, and in a few moments, your carb will be like new. Kathy will keep them in line.
Ask me how I know
jack
PS how did you beat me to this post ? you read my mind
To Holley Carb Rebuild Help
Old 03-04-2011, 04:10 PM
dahogan
Enjoy while you can.
dahogan's Avatar
Received 2,684 Likes on 1,272 Posts
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Yep, we'll fix it alright.
Old 03-04-2011, 05:16 PM
w1ctc
w1ctc's Avatar
Holleys are just not that complicated. The trouble comes from various "improvements" that were done over the years. A magazine article, the local "expert", mixed parts, wrong gaskets, extra holes and way off jets, wrong power valve and accelerator pump parts all conspire to make a mongrel that will never run right. As long as nothing has been changed and no warping. It should be easy to rebuild
Old 03-13-2011, 09:39 AM
dahogan
dahogan's Avatar
Ray
Midyearvette does. Carb clinic day was yesterday. Frank brought over your carb after rebuilding it and bolted it on my 66 L 79. Perfection Ray, you chose correctly my friend. And while he was here he tweaked mine as well. Yours should be on its way back home soon but w/o a bottle of Dewar's. Amazing what knuckles will do for a few beers. Thanks Frank
Quick Reply: Holley Carb Rebuild Help
