C1 Remote Trunk Release?
I have had a Halon Fire extinguisher for awhile now and it is time to install it but because it is not the really small type that usually is used it just doesn't look right in the cockpit. So it has to be installed in the trunk, actually I am using a Drake extinguisher holder/release just inside the trunk behind the trunk latch All that is great BUT as you know I still have to use a key to pop the trunk and in case of a fire, I don't want to stand there watching things go up in flames if I don't have the key
My Question? Has anyone installed a remote cable and hooked it up to the trunk latch? If so can I tap your knowledge??
Use an electric trunk opener solenoid from any 80's GM G body. Preload trunk lid with small spring (like on 62 vette). Yellow button and wiring could be placed anywhere inconspicuously.
Fred
Fred
Don't know if I want a gas tank between me and my fire extinguisher...or some cobbled together aftermarket mechanism to get to it. Get a smaller extinguisher.
Small Fire Extinguisher
Thanks for the suggestion but have you ever had to use a small one? They are a pretty much a one blast unit. Like HP/Torque, I'd rather have more than enough than not enough!
That reminds me of a race at Moroso one weekend. I was working Turn 9 with some friends and this guy in an old circle track car he converted to road racing caught fire going past us into 10. Turn 10 responded, signaled for help, and three of us from 9 responded when they couldn't get it out.
We went through 10 regular bottles (not something small like you have in a car) before the fire truck was able to pull through the paddock to get there.
This was an engine fire on a metal car. You really don't want to see a plastic car burn.
Frankie, that little bottle in the glove box is best used to put out that cigarette that fell on the floor or if the air cleaner catches fire when the carb backfires. Anything else, you will have better luck ripping your jacket or shirt off and smothering it.
St. Jude Donor '07
i now carry a BIG fire extinguisher in the trunk.
Bill
btw: i had had the same thought about adding a remote trunk release for the very same reason
On my first 62 the previous owner mounted a cable with a pull button in the glove box to the trunk release. Worked great, which was a good thing cause the key never worked in the trunk lock.
In the time it takes you to: a) remember you have a "big" extinguisher in the trunk, b) mistakenly run back towards the trunk with the key because in the excitement you forgot about the hidden trunk release, then, c) run BACK to the cockpit release the trunk and get the extinguisher....I'll have doused any fire I care to tackle with my little guy 1 second and 1 click from my right hand. Anything bigger than that and its an insurance claim IMO.
Anyway, I've put out one engine fire on the car already with an A/B/C extinguisher the same size....and had to clean up the engine for a whole day afterwards.
St. Jude Donor '07
lol...
Frank, if you run back with the key; then you don't need the button....
i have a small spray carbon tet extingisher in my console box (suitable for a kitchen fire), but neither mine or yours might not have saved my front end from what was a gasoline fire; a BIG A/B/C probably would have and i'd have gratefully cleaned up the mess (and i would have had all the time in the world to open the trunk)... so, i stood by and watched it burn; the only thing that kept it from being a complete loss was the the top was up and the windows were up and so the fire essentially snuffed itself out.
the fire was so hot that the upper a-frames just folded over...
Bill
Bill
If'n you gots da key in yer hand, use it?!
I will say that at least you have a extinguisher in your car, I can't tell you how many don't. It is pretty sad to see someone about to open a smoking hood without one. I have owned my Corvette longer than most and it can't be replaced. Carry what you want but give me a decent size Halon anyday!
I'd estimate 15-20 seconds to put out my engine fire...that includes trying to throw an old flannel shirt on the burning manifold (totally useless gesture)...then getting the fire extinguisher and it wasn't more than 2-3 squirts and the fire was out. Any longer than that and it would have been 9-1-1 time and clear out for the experts to go to work. I'm not dying or even getting 2nd or 3rd degree burns over a machine...no matter how nice.
From your pic of your little extinguisher...
Oh well, as I said before and I ending this discussion with "I'd rather have more than enough rather than not enough! HP, Torque and fire extinguishers..
BTW, I have owned and held onto my 1959 Corvette for going on 42 years now. Cheers
From the pic of your fire extinguisher, it appears to be a Halon, if so the discharge rate is about 8-10 seconds so it must have taken you 5 to 10 seconds to throw and remove the "flamable" flannel shirt (why did you do that?) :o You can usually blow out a carb fire due to a backfire.
St. Jude Donor '07
My fire occurred in my garage before I had the fire extinguisher in the car so I after the non-effective shirt deal I had to run across the garage and unlatch THAT extinguisher from the garage wall...sorta equivalent to getting one out of your trunk .. ya think ?
Bill
