How can I lower my rear end on my 66
Just finished frame off on my 66 small block Conv. All new suspension. The rear spring is the correct 9 leaf for this car. It's 2 inches too high. What should I do. Longer bolts?
Received 1,857 Likes
Got photos of the rear spring?
Springs
Your springs should relax a bit over time. You can buy longer spring bolts from Vette Brakes and Products. Since they are in St. Pete, they are almost local for you. Jerry
as stated in time it will come down a bit but not that much...John Z was more on the money ...which procedure did you do when reinstalling the componets? yes longer bolts will give you more adjustment on the height...how far up did you tighten up the nuts on your spring bolts? perhaps you have a couple of threads you could loosen the nuts back to?? you might have the correct number of leafs in your spring set up but at what spring rate is it??????
