59 Main Wiring Harness Routing Question
I am on the final stage of completion of rewiring the entire car, and reinstalation of the instrument cluster and need a picture or a good verbal reply as to exactly how to route the DASH portion or the main harness (pictured below) as it loops around the parking brake lever. The AIM is pretty vaguely detailed and seems to indicate a support clip which I am missing as well as a plastic loop wire support (pictured) but not sure where it would attach either.
Here's a picture of what I am talking about:
Any help or picture post of correct routing would be greatly appreciated so I can finish this up. Thanks in advance. Pilot Dan
Thank's Jeff for taking the time to post that picture. I pretty much figured it out last night when I did not get any replies what I needed to do. Your picture confirms that and is much appreciated.
The good news is everything powered up perfectly on the initial try.
Always a bit of a pucker factor when you connect the battery for the first time after rewiring the entire car. Pilot Dan
