How To - Step by Step A/C Compressor Front Seal Replacement
Excellent write up Jeff. Just curious though. All those tools and the recovery machine must have cost a fortune. How does it compare to having someone install the seals?
However, I did not purchase the tools in support of a seal replacement. When I purchased my 65, it came with 60 lbs of R12 waiting to be used.
This 65 is one of 4 classic cars I own that use R12, the other 3 cars all needing some level of A/C repair.
I wanted to learn how to do all this myself so that I could be self-sufficient, and be able to diagnose and repair cars in my collection without having to rely on others. So I purchased equipment necessary to evacuate and recharge the system, and then also bought the tools necessary for a seal replacement. I will need other tools if I actually try to rebuild the internals of a compressor myself.
All of that having been said, I have no idea what it would have cost to have the A/C seal repaired and the system charged at a shop, but the sense of accomplishment I get from driving the car with working A/C that I fixed myself, is huge.
Jeff
Great presentation Jeff, very informative. I have a simple question that you can probably answer. I am restoring a '65 with A/C. The NCRS Technical Manual says the the Evaporator Housing has a Harrison Foil Sticker which reads: EBA-70-65B. But, it doesn't say where on the Evaporator housing the sticker is located. Any idea "where" on the housing it goes?
Thanks. Jim
Thanks. Jim
Good job,
This is my 1st post and it was nice to look at your pics.
you certainly make it look easy and explain each pic wonderfully.
I specialize in A-6 and have had a number of classic air
re-seals come thru my shop.
I get into the gut pac and ring them with the metal ring they used from 63 to 75.
Some parts cannot be found (metal rings & thrust spacers).
The corvette piston is dished and the passenger piston is a flat top.
A gut pac apart in the pic.
I have had rebuilds sent here for inspection that only had O-rings and the front seal replaced and the gut pac with bearings, spacers,
rings, and wear not checked. I test em with over 300 lbs nitrogen for leaks and there go's a few days.
DOM
DOM
My apologies, I just saw these posts.
Yes R-12 is still available, e-bay is a common source I've come across.
Jim, I'm sorry but I am unaware of the correct location for the Harrison foil sticker.
Dom, thank you for the kind words, I'm pleased when someone who does A/C repair as a business, feels my amateur-based instructions are worthy of note.
I also noticed you were able to Attach photos to your post, without also having to be a paying member. This is an AWESOME improvement for the forum, finally everyone can include photos without having to use PhotoBucket or other hosting services.
Thanks. Jim
Thanks. Jim
I think I'll ask the moderators to remove this is a Sticky now, as there are too many stickies on the forum these days.
Received 1,857 Likes
