Spicer Half Shaft Universal Joint Problem
I bought a set of Spicer universal joints for the halfshafts on my 65. The universals pressed into the half shafts without a problem. But they seem too big to fit into the halfshaft flanges. I checked with a straight edge to see if the back of the flanges were bent, but they do not appear to be bent. Has anyone seen anything like this? What is the distance between the ears on a new halfshaft flange? Maybe my ears are bent inward slightly.
Bill
Bill
It's very common for those to get bent a little from pounding the old ones out. Measure what you have, then take it and bolt it back on the spindle and compare. Maybe you can get the u-joint started when you have it bolted up, and remove it to finish the job?
Gerry
Gerry
Bill
Bill
I don't know the exact word, but with the caps removed, the u jouint does not fit into the flange. The part of the u joint with the cap removed hits the flange ear about 1/8 inch.
Bill
Bill
I just measured the distance between the flange ears on my half shafts as best I could. I get about 2 5/8 inches. The distance lessens as you go closer to the plate end because the ears get wider. I don't know if the ears can move with the plate bending, but did you put a straight edge against the back of the plate? Although 1/8 inch is a lot to bend. I've only done drive shaft u joints, so I have no experience with this.
larry
larry
You may have the wrong size u-joints. Do you have the old ones to compare the new ones to?
Received 1,857 Likes
Any time you're doing the outer U-joints on half-shafts, you should use either another flange, bolted back-to-back to the one you're working on, or a piece of plate stock drilled and tapped to bolt the flange to, to avoid distorting/bending the flange while pressing the U-joints. Bending the flange and/or the ears is VERY common when the proper support tool isn't used, and when the flange is bent, it's junk.
BOOT77 (07-29-2021)
If I'm reading this right it sounds like the same problem I had when I installed the Spicer U-joints in my half shafts. The cross, or trunnion portion is pretty beefy compared to a standard size U-joint. In order to fit the the Spicer cross inside the mounting 'ears' of the half shaft I took a Dremel tool and slightly ground away a bit of inner ear material to allow clearance for the trunnion end to clear and enter the ear. It didn't take much - only a tiny slight amount of material was removed.
