64 Corvette Horn Relay
Where is the Horn Relay supposed to be located on a 64 vette? Car has been previously modified and I would restore to street legal and somewhat original condition starting with installing horns and relay.
Thank you!
Kevin
Thank you!
Kevin
Received 1,856 Likes
Without A/C, the horn relay mounts to the passenger side of the radiator support, with a ground wire from its attaching screw to the base of the voltage regulator, which is mounted adjacent to it on the inner fender. Suggest you get the '64 Assembly Manual - it has all the details and illustrations you need.
