Pertronix Kit and Coil Question
I just finished installing a flame thrower coil and a pertronix kit for the distributor in my 62 327 300 hp. The install went well . My question is I thought I saw somewhere that the spark plug gap should be changed when using this setup. Can anyone confirm or deny this please.
thanks
Warren
It's Friday !
thanks
Warren
It's Friday !
2018 C1 of Year Finalist
thanks
Warren
It's Friday !
thanks
Warren
It's Friday !
I widened mine from .035 to .040 - some go to .045. However, I detect no difference in how the car runs... I sure wouldn't pull the plugs just for this tweak..
Keep an eye on that Flamethrower coil. I have blown two of them. Sent them to Pertronix and they refunded for both no questions asked.
Seems both solid and oil filled crack wide open. Pertronix knows of the problem. But they keep selling em.
My old GM coil still works great. No issues with my Pert II.
2016 C2 of the Year Finalist
I also went through two Pertronix coils in three years. Didn't think to send them back but bought a NAPA coil and all has been good now for a few years without a problem. If you're going to drive with the Pertronix, I'd make sure you carry an extra coil with you. My old coil I just happened to have with me saved me twice. Dave
Flamthrower last ONE DAY!!!!
So I go to start my car and the darn thing just turns over and over and over and doesn't run. I take the flamethrower out and put it the stock napa coil and booya, it runs. I'm very disappointed with the product. The coil basically lasted for one day.
When I installed the pertronix kit the car would not start until I bypassed the ballast resistor. The car would fire but it wouldn't stay running so I bypassed the resistor and the car ran. Can anyone confirm if they also bypassed the ballast resistor.
thanks for the help
Warren
thanks for the help
Warren
thanks for the help
Warren
thanks for the help
Warren
Did you read your instructions?
The Pert II and III by-pass the ballast.
Why is Pertronix still selling these junk coils????
This has been well known by Pertronix for over 2 yrs!!!
To be fair to Pertronix, I had an Accel coil fail the same way. Seems the only coil that doesn't fail on a Pertronix ignition,is the stock coil.
There may be an engineering explanation for this, but I haven't found it. Since the GM coil works great. There was no reason for me to waste more time on it.
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
I am using the MSD Blaster coil with no problems...I also bypassed the resistor.
Welcome to the club.
Warren
The Ignitor III wants the full 12V (e.g. NO ballast resistor)....I have made the earlier versions work both with or without the resistor however.
Never had a FlameThrower coil fail and I've run 4 on cars that I can think of. Did have a high-performance Accel ignition coil start leaking oil though after a short time on the '61....I think the vibration is too much for them maybe...
Just go to www.jegs.com and type "Pertronix" in the search box -- you can get just the module that goes in your existing distributor or a whole distributor, like I did with this product:
http://www.jegs.com/i/Pertronix/751/D7100701/10002/-1 It fits under the ignition shielding, has a vacuum advance and rev limiter. You may (or may not) need an ignition coil to match and if you are fuel injected (distributor drive) tachometer then you better go with the internal module instead.
Yep add another name to the list of short flamed flamethrowers owners.
Wish I knew then what I know now about the rash of flamethrower flameouts.
