Help Needed: 327 RE Engine (340hp, 365hp?)
Old 08-26-2011, 08:16 PM
dsdissin
4th Gear
dsdissin's Avatar
Default Help Needed: 327 RE Engine (340hp, 365hp?)
Hello all, I'm a new member and I need some help from the Vette experts... I just purchased my friends 327 that we always thought was a '64 Vette 327 365hp engine (RE code, factory domed GM pistons, steel crank, it had a GM solid lifter cam in it, 461 heads).. But, now that I dig in I'm not so sure, I believe is may be a '63 327 340hp.. Here are the details on the motor and heads:
Engine Casting - 3782870 / Date - E 24 3 / I.D. - F0603RE
Heads - 8782461 / Date - E 23 3 & E 9 3
-The motor is standard bore and does not appear to be decked, but there is no VIN number on the ID pad just a very define engine ID number. Did some engines come through without the VIN stamped on the pad?
-The Heads appear to be the correct castings and date range to be original to the engine, but have 1.94 X 1.50 valves. Is it possible that the 340hp / 365hp engines may have come through with these heads?
-Estimate on what it may be worth?
Thanks for any help,
Dave
Old 08-26-2011, 08:36 PM
365GTB4
Support Corvetteforum!
365GTB4's Avatar
63' 340 hp replacement engine. No idea on the worth.
Old 08-26-2011, 09:07 PM
MiguelsC2
MiguelsC2's Avatar
St. Jude Donor '10-'12-'13
Welcome to the Forum. You found a great place for Vette info.
Depending on condition? Not much.
All the dates look good. It's a 340 hp.
Same bottom end as the later 365hp. But the 64 used the 30-30 cam and the '63 340hp used the 097 "Duntov" cam. The 365hp also used 2.02 and 1.60 valves.
Old 08-26-2011, 09:12 PM
62Jeff
62Jeff's Avatar
Cast in May 1963, assembled in June 1963, not for assembly line installation for a 64 vette.
To Help Needed: 327 RE Engine (340hp, 365hp?)
Quick Reply: Help Needed: 327 RE Engine (340hp, 365hp?)
