Quick Rim Question
Quick Rim Question
PICTURES ADDED
I have some Rally wheels and need to know if these came off of a vette or something else
DC by the stem an HK and GM by the lug nut areas.
Did i luck out or bust?
Received 6,943 Likes
2015 C2 of Year Finalist
HK is kelsy hase and GM is general motors. What is the date on them. It's located on the inside.
Crap... they still have rubber on them...knocking them down in the am...
All i know is they are for sure 15" plus what you just told me...
How do i determine if they are for a Vette?
I think DC is vette only. Are the seems welded or riveted
Pictrure added
ALL 4 RIMS HAVE THE SAME MARKINGS
ttt
bump
Received 1,283 Likes
I "think" DC code is 67 Corvette (15x6) and 68-70ish passenger car (15x6). The Corvette wheel, if I recall, has a "larger" DC than the passenger car wheel.
I'll bet if you google something like Chevrolet wheel codes you will find a bunch of information.
Jackpot! Large DC are original '67. Smaller DC and riveted are replacements and the slots will be shorter.
Do the pics i posted help in noting if the DC on the wheel is the large or small "dc".
Received 1,857 Likes
John: That's what mine look like but not as clear...
jack
jack
Looks like the correct "DC" stamp to me - if it's real, a quarter will fit vertically through the slot.
John:
I just took the test..passed with flying colors...
John:
Does anyone know if the wheel codes are based on months, as are other parts? On my 64 I have a set of original 68 rallys that are stamped with "AG" which add up to 8 (68) the above "DC" add up to 7 (67) just curious or was someone just blowing "theory" smoke at me
AG 15x7 -.28 JJ 3910799-D 68 Corvette
DC wheels are definitely 6"...
DC (early) 15x6 +.06 JK 3968733-D 67-70 Passenger Car 67-70 Station Wagon
FI (late)
DC 15x6 +.06 JJ 3901698-D 3968733-D 67 Corvette
Good luck... GUSTO
Thanks Gusto, I like your theory better!!!
Jack
Passing a $.25 piece through the racetrack slots does not reliably identify a '67 Corvette OEM rally rim. With the exception of the FI (riveted) and the YS (late '69) 6" rally wheels, all other 6" rally style will "pass" the quarter test when measuring slot size. That is, the large DC, small DC, early '67 DG, & Z28 Camaro DF wheels all have the larger slots.
All this 'test' will do is to rule out an FI or a YS without removing the trim ring to view the valve stem area.
Your rims are indeed '67 Corvette only. To find their dates, look on the hoop section when the tires are dismounted. Follow the photo below (DF Z28 Camaro counter wheel used as an example); Your should see a rim contour code of 15x6JK. Near those characters, look for crooked & light stampings of a letter and one or two numbers. A 5, for example meaning January 5th. In the same area of the hoop, look for another set of character in a cluster of three. K = Kelsey Hayes, 1 = Romulus MI plant, 8 = 1968
