Help with headlight motor adjustment 1966
PASSENGER HEADLIGHT ON MY 1966 WONT GO UP UNLESS I LIFT IT MANUALLY FIRST ( JUST BARELY ABOUT 1/8 INCH). THEN IT GOES UP JUST FINE.
OTHER THAN THAT BOTH HEADLIGHTS MOVE UP AND DOWN QUICKLY AND EVENLY.
IS THERE AN ADJUSTMENT TO FIX THIS OR DO I NEED NEW GEARS?
DONT THINK IT IS A MOTOR PROBLEM AS THEY BOTH WORK FAST AND EVEN?
ANY HELP WOULD BE APPRECIATED
in the FAQs section under Sticky Notes, there is a headlight motor rebuild article discussion. More than likely you will need to flip/turn the gear 180 degrees. Had similar problem to yours and the that fixed it. Below is the link directly to the thread.
http://forums.corvetteforum.com/c1-a...-assembly.html
Received 1,843 Likes
Location: going faster miles an hour...with the radio on in browns mills new jersey
I found that most all of the wear on the gear is at the beginning and end of its travel. As these points are about 180* apart, flipping the gear didn't do a bit of good.
If you get a new gear make sure it fits properly on the shaft before you install it in the motor. You may have to enlarge the hole a bit.
