How to install center arm rest on 63 vette?
I ordered a new center arm rest (you can't really rest your arm on it--it's just a pad between the two seats) for my 63 vette convertible.
I can't see how to install it.
I'd like to get it done today so the wife stops complaining about the tear in the old center arm rest.
Can anyone post directions?
Thanks.
Thanks.
If it's the same as my 65, you have to remove the center trim at the shifter, which will expose a bolt in the leading edge of the cushion.
Removing that bolt and then the cushion should come out.
The new cushion has a pin in the back of it, which penetrates a hole in the luggage divider between the seats. Insert that pin into the hole then place the leading edge of the cushion down so you can reinstall the mounting bolt.
Don't let you wife know that the purpose of the arm rest pad, assuming you have a convertible, is for your hot date to sit on. I got pulled over in Honolulu one Saturday night with two guys (I was one) and three babes in my Corvette with the top down. Personally I think the cop was jealous we had more girls than guy in the part group.
