1x4 or 2x4 WCFB power vs fuel consumption questions
Old 09-20-2011, 09:57 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
You need a spacer (which are available) or the riser valve...one or the other but you have to have something in that 'gap' in the system. But I just took some stainless steel aircraft safety wire and wired my exhaust riser open...
Old 09-21-2011, 12:18 AM
mickatbp
Support Corvetteforum!
mickatbp's Avatar
Thanks Frank, I have SS aircraft lockwire at home. I'll get the FI intake manifold gaskets and the phenolic blocks. There is a correct manifold on ebay now, I'll see how I go with it. I figure around the $200 mark is okay.
All, thanks for help and advise
Old 09-21-2011, 08:09 AM
CJS
CJS's Avatar
Nocticeably more power with 2x4's. You can easily test for yourself by disconnecting the front carb and run on the rear only, then retest with both. ----------------------Fuel distribution problems are non-existant in a well sorted out 2x4 system. The rear carb's front 2 butteflies are near, but rearward of the center of the manifold. Just like a 1x4's front 2 butterflies are near, but forward of the center. ----------------If you doubt this, consider a Chevy stovebolt 6 cyl. engine. Look at the intake manifold. Hugely unequal lengths and still works great.
Old 09-22-2011, 12:28 PM
mickatbp
mickatbp's Avatar
Frankie the Fink .......... pm/email sent
Old 09-22-2011, 01:04 PM
Frankie the Fink
Army
Got it and responded via email..
Quick Reply: 1x4 or 2x4 WCFB power vs fuel consumption questions
