1966 Convertible Soft Top Installation Advice
Old 09-22-2011, 02:02 PM
bigdell66@cox.net
bigdell66@cox.net's Avatar
Default 1966 Convertible Soft Top Installation Advice
I'm preparing to install the tack strips and weatherstripping on my 66 soft top. Can anyone advise on the best way to install the new tack strips (adhesive, method, etc.) ? I also would like to know whether to use adhesive on the bolt -on window weather strip pieces that fasten to the soft top frame.
Old 09-22-2011, 09:19 PM
woodsdesign
woodsdesign's Avatar
If you are using original type tack strip then you should not need any glue. I usually press them into the channel on the #3 bow. Also, press them into place where the pads attach to the 1 and 2 bows. Tabs will hold the tack strips onto the header bow. The problem comes when the tabs on the header bow rust and cannot be used. Then you will have to use sheet metal screws to attach the tack strip and grind them off smoth with a small grinder. This is very common.
If you are using plastic tack strips then you may have to use glue to hold them in place on the 1, 2 and 3 bows.
Old 09-23-2011, 02:03 PM
bigdell66@cox.net
Thanks for the advice, I really appreciate it.
To 1966 Convertible Soft Top Installation Advice
Quick Reply: 1966 Convertible Soft Top Installation Advice
