camshaft for more torque on a L76
on a 327ci 365hp (the L76 engine), torque/power is low in the low rpm range. If I am correct the camshaft opens the valves over about 250 degrees. However I do not want to speed at 140mph, nor race in the high rpm range. My prime use would be to cruise gently at 60-80mph.
Is it realistic to put a different camshaft (more conservative timing) for more low end torque, sacrificing some top end power, anyone has done this before?
Sure! Try something like 225/225 degrees duration on a 112 degree lobe separation angle (110 degrees works too!). Be sure to advance the cam 4 or 5 degrees.
BTW, the L75 cam has 222/222/114 degrees and work well also (it's the 327/350 hp cam).
You have a great camshaft already, why don't you advancing the camshaft timing to 2 or 4 degrees, this will move your power band to what you’re looking for without changing your camshaft. Just a suggestion you may want to try before playing the dreaded select a cam game.
rustylugnuts
rustylugnuts
Of course, the entire discussion assumes that you have as much spark advance in your ignition system as the engine will take before detonation sets in. Ideally, if the engine will run detonation free with about 16 degrees initial, with the other 22 degrees all-in by 2500, then you can't ask for more than that. Well...actually you can, and that's 20 degrees initial with 18 centrifugal all in by 2300, but I doubt that the engine will tolerate it.
I doubt whether advancing the cam by 2 degrees will make a significant difference, enough to satisfy you realistically. Another trick would be to detune the cam by opening the lash to .030"/.030" if it's not set there already. Again, this is good for a small increase in torque at the cost of a small amount of peak power. Both are band-aids, AFAIAC.
So, the first question is whether or not you want to retain solid lifters, or not. If you want to retain solids, then the stock LT1 cam (Speed Pro CS1145R) will give you noticeably more bottom end with a sacrifice in peak power. This cam is happy with the same static compression as the 30-30 cam. If you want to use hydraulics, then another stock Chevy cam that works well with your static compression ratio is the L79 cam (Speed Pro CS179R).
thanks for you comments, I agree that changing timing is a far less risky game, but may not give enough punch increase in the bottom range.
I have never rebuild an engine, only read two books and studied one 2hr video on small block rehaul, does not make me an expert ;-). If I understand correctly, then it takes removal of intake manifold, rocker covers, rocker/rods/tappets, before the cam can be pulled out. Is there a catch somewhere ? I read that replacing the cam and NOT replacing the cam bearings is an absolute no-no. Is that true?
You will also need to pull the hood,radiator,fan,pullies,water pump,timing cover etc... Cam slides right out. Make sure you get the timing marks aligned on re-install. Other will suggest advancing the cam timing. Might want to seek pro help on that one.
Be sure and do your home work before tearing it appart.
No offense, but may I ask how long you've owned your Corvette? I'm just wondering if you recently purchased it, unaware that the car had a true high performance engine with a "rough edge" that you weren't prepared to live with.
IMO it's always sad to see someone lowering compression, installing milder cams, etc. in hero motors like this; it's like cutting off an alpha male's *********. Hot cams and high CR's are what make motors like this special and extra desirable to many enthusiasts.
Really, is it out of the question to sell your current Corvette and then buy a C2 with a milder motor (such as a 327/300 or 327/350) and other amenities that you might find easier to live with? If you wouldn't have to take a loss maybe this is the best solution in your case. Just a thought.
I'll know more next week when I'll do a new test ride, mainly to qualify the engine. My question on changing the cam is related to the direction I would possibly choose when more toque is as simple as swapping the cam. Now, I don't know how well this engine has survived time, so I may need to replace it anyway. We'll see, it's part of the fun too to do the homework well, read and learn, it's a great learning experience, and the cheapest part of restoring a car ;-) . I know, because I just finished building a Cobra replica
Received 1,843 Likes
That cam ought to be just fine for that speed. Don't let the degree numbers fool you on the cam. It has LOOOOONG opening and closing ramps.
Contrary to popular internet myths, There's nothing wrong with the low end torque of the cam in question. There's more than enough to haul that car around at low speed. Just select the proper gear in the transmission.
If the engine won't run decent at low speeds, check the carburetion and ignition.
After reviewing your replies, I strongly suggest you find a professional mechanic who specializes in American muscle cars drive and evaluate this Corvette. Guessing and assuming mixed with inexperience can be a volatile mix, not to mention very costly!
rustylugnuts
rustylugnuts
low end torque
I have a '64 with the L76 engine , I do not like the take off [launch speed] in first gear also. I always blamed it on the first gear ratio in the Muncie trans. It has the original CLOSE ratio Muncie type gear box in it.
I have a '60 Corvette that has a non- original Muncie WIDE ratio gear box in it and the launch speed is much , much better.
rustylugnuts
Received 3,043 Likes
St. Jude Donor '05
id change cams before dorking around with advancing/retarding, that rarely makes a sizeable difference.
