Rearend snubber replacement / confusion
Old 09-30-2011, 04:24 AM
DSR
DSR's Avatar
Default Rearend snubber replacement / confusion
After searching and going through many pages of posts i'm still confused
1: " drill holes in floor for bolt access"
2: "drop rear end"
3: "just pry down on the front of the pinion bracket with a large screwdriver to remove / replace snubber"
I'm hoping for number 3.
Dave
Old 09-30-2011, 08:12 AM
CP64365
CP64365's Avatar
#3 worked for me, but I used a pry bar. Just be careful not to damage your brake line.
Old 09-30-2011, 09:20 AM
Tampa Jerry
Tampa Jerry's Avatar
Received 1,328 Likes on 960 Posts
Default Snubber
Go with door number three. Do not use a polly mount. It changes the pitch of the rear and will cause problems. Jerry
Old 09-30-2011, 10:04 AM
65air_coupe
65air_coupe's Avatar
#3 easily worked for me, hardly any prying to be done that I remember.
Old 09-30-2011, 10:18 AM
TXSTICK
TXSTICK's Avatar
Old 09-30-2011, 10:13 PM
DSR
DSR's Avatar
So, #3 it is. I'll try a pry bar. Thanks Dave
To Rearend snubber replacement / confusion
Quick Reply: Rearend snubber replacement / confusion
