Jim Meyer IFS Power Steering Hoses
Are there any of you that have put a Jim Meyer IFS on your C1 with power steering that can help with what can be used for the preasure side power steering hose. I am using a type two GM remote reservoir type pump that came with the March serpentine belt system. Not having much luck finding the correct fittings. JM supplied a tight 90 degree fitting with a top O-ring seal where it seals and AN-6 outlet to be used at the rack but it doesnt look quite correct. Haven't had much experience custom making PS hoses and not sure where to start. March suggested a 16 MM bango fitting out of the pump but I haven't found anything like that yet. I hope someone out there has been through this and give some direction.
Gary
Gary
Around here, in Phoenix I go to the Parker Store, there should be one maybe near you, they are well stocked and able to make anything for auto's or backhoes, industrial equipment.
http://parkerstorephx.com/
they are part of a larger network
http://www.parker.com/portal/site/PA...006d00d40aRCRD
