Please explain 870 block stamping, to me.
I am interested in any clear pics of a 64 327/365 block stamp, to see what it looks like. Why do I see sometimes only one set of numbers, and yet I have seen blocks with two sets of numbers.
I would like to see a very clear example of a 64 327/365 or something that would be the same, thanks for any help.
Platinum Supporting Dealership
................ or do you mean two sets of numbers ? The assembly date and the VIN sequence and suffix. This would be normal.
Here's one I pulled using a Google search. No idea who's it is or if it's real, but this is basically how the stamp should appear.
__________________
Tom Hendricks tom@budschevy.com
Corvette Specialist Since 1993
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
WEBSITE WWW.BUDSCHEVY.COM
HOURS MON-WED 7:00AM - 5:00PM
FFRIDAY AND SATURDAY BY APPT.
OFF THURSDAYS
NCRS # 23758 Miami Valley Chapter ( Ohio )
NCM Founding Member #1143
NADA Classic Car Guide Advisiory Board Member
C5/C6 Registry Corporate Member # 5
My Corvettes. 63, 71, 73, 78.
Facebook Post
BUDS CHEVROLET
St. Marys, Ohio
800-688-2837
OFF THURSDAYS
You mean two sets as in a "double strike" where the stamp bounced ?? Those are not really uncommon. It will appear as two sets, one on top of another.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
Any 870 block installed at the factory will have both sets of numbers. Over the counter blocks at the dealership only have the build date and suffix. No ID because it was not installed in a car.
Received 1,283 Likes
Early passenger car blocks did not have the necessarily have the VIN number stamped on them.
I had a 66 Chevy II SS with the original 283. It had one set of numbers stamped on the pad, the engine plant stamp.
I have seen a 1967 Impala 327 engine with just the engine plant stamp; no VIN.
I have seen numerous examples of this. VIN stamping on the pad for all engines became standardized around 1968 / 1969 time frame.
I have also seen engines where the engine plant stamp was done using a gang holder (all characters nice and even) and the VIN was stamped individually. This was in a 64 409 Impala.
My guess is that VIN stamping was originally started as a theft deterrent for "highly desirable engines".
This is also one of the reason that passenger car single letter engine suffix code blocks are so desirable. Add a letter to make it whatever HP you want, and stamp your own VIN. Been done many times.
Received 1,857 Likes
In the mid-60's, usually only the optional performance engines in passenger cars got the VIN derivative stamp on the pad; standard engines didn't.
Photo below is a typical '64 Corvette pad (L84 fuelie).
Thanks guys, I think now I understand why some have two sets of numbers and why some only have one. This does answer my original question as to why, thanks.
That is still what I am trying to be sure about, if it only has one set of stamps, does that mean it is or is not original. Does anyone else out there know they have an original engine with just one set of stampings.
It's Oct. 7, (58?) with two fours and a manual tranny. The CS was used several years, but it would have the vin after November 59. If you are correct about the born date, your engine is way too early for your car but anything is possible I guess. The block would not have had a vin number in October '58. What is your vin? Did you look at the block casting date on the rear passenger side of the block?
http://forums.corvetteforum.com/c1-a...nal-motor.html
See post 12
October, January, whatever it takes....
See post 12
See post 12
Block Stampings
You are incorrect stating "every" corvette built left with both stampings. There have been several documented corvettes
that only have the engine assembly stamp & no vin. It all
depended on the motivation level of the assembly line worker
that day.
Have you just come out of a coma? This thread is well over 5 years old!
Gary
Gary
