Corvette Lookalike Midyear Shifter T Handle
Is the same handle used for the Hurst Comp Plus as is used with the Keisler and Tremec TKO and RS kits?
Need to replace mine for the Hurst linkage and want to use it when I get the Keisler RS 600 next year.
It should fit. On my Camaro, I took the lever that was bolted to the Hurst shifter that was on the Muncie, and bolted it onto the shift linkage on the Tremec that replaced it.
2019 Corvette of the Year Winner
St. Jude Donor '15
The shift handle for my tko600 had this bolt pattern. As long as your handle has two holes to mount up assuming the mount is like the tko then you should be set.
