Eaton Springs
Eaton Springs
I have a 66 coupe was looking on replacing springs all around to get a lower stance / Eaton offers rear leaf in normal and heavy duty -1 to -3 in height has anyone tried these or even looked at there product
thanks
thanks
Received 1,857 Likes
The Eaton-Detroit reproduction 9-leaf 2-stage rear spring is the closest one you'll find to the original; I have one on my '67. Don't know anything about any other non-standard ride height versions; not a great idea to mess with basic ride height, as it affects geometry.
Please, Please, go to www.corvetteusa.com, get their phone # and ask to talk to Mike.
Tell Tim Tschanz (pronanced Chance) sent you. The ONLY proper suspension available.
Got the F40 ( reg available in 6-9 mo) could not be happier. Ask them about Eaton Spring
now!
Tim
now!
Tim
now!
Tim
now!
Tim
Rick
The Eaton 9 leaf will give you the proper height. But I found it too soft.
I went with Eatons 7 leaf. When ordered, I added 1 inch to keep the level consistant with my non F-41 front springs.
Not sure of the need to slam Eatons products. Excellent products and service.
Not sure what Corvette USA is offering? If they are falsely spreading negative rumors about the competition? I would not do business with them anyhow.
A reputable supplier let's their products do the talking.
With that kind of turn around someone else is making them.
Not slamming Eaton Springs but they are what they are.
Up until reciently their web site stated they are not exact repros because the correct original material was not available to them and I think they will tell you that today.
Due to an incorrect rear spring and ride height on my '63, I started looking for a solution earlier this year. Several threads on the NCRS forum related the problems with current Eaton repros - ride height wrong & too soft.
Looking for a better solution, I found CorvetteUSA. They have accurately reproduced the F40/F41 suspension, springs, shocks, & sway bar. Some would say this was too harsh a suspension in its day.
However, "in its day" the average speed was much slower and all suspensions were marshmillows. As speeds have gotten higher and roads better all car suspensions have gotten stiffer for better performance.
Mike @ Corvette USA guaranteed the ride height would be correct and promised I would be happy with the ride and handling of the F40/F41. Realize, if you have radials they soffen the ride compared to bias ply. Although, not NCRS correct for a '63 without big brakes, I could not be happier. The ride is actually slightly softer than my Mercedes SLK350
For those wanting a NCRS correct regular suspension, Mike told me at Carlisle they would be available in 6 to 9 months.
Thanks for the info, un like lots of guys i really like the apperrance of a lowerd car , that was the reason i was looking and found eatons add on the lowered springs , i do have an original small block with air 66 coupe all # s car it is one of the tightest coupes i have been in , i just recently painted viper red and few other things
