64 Diff. Code?
Old 11-12-2011, 09:58 PM
K5kaos
Support Corvetteforum!
K5kaos's Avatar
Default 64 Diff. Code?
Wondering if anyone can help make out this code on 64 vert. diff?
Old 11-12-2011, 10:00 PM
K5kaos
K5kaos's Avatar
Here is an overall view.
Old 11-13-2011, 04:07 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
The Julian date code (3 3 4) pretty much confirms that it's a '78 or '79 3.55 Posi ("OH") axle, made on the 334th day of the year. The casting date will be on the driver's side, partially hidden by the front of the strut rod bracket.
Old 11-13-2011, 11:23 PM
K5kaos
K5kaos's Avatar
Wow, John!!
Thanks!!
Your knowledge base is amazing!
Here is another pic from the same diff.
Located on rear pass. side
Old 11-13-2011, 11:27 PM
K5kaos
K5kaos's Avatar
More pics:
Old 11-14-2011, 12:29 PM
JohnZ
JohnZ's Avatar
Yup - the 464910 rear cover was used in '78-'79, with the 7/16" rear spring retainer plate bolts (vs. the 1/2" bolts used from '63-'77) to accommodate the '78-up 2-1/4"-wide spring.
Old 11-14-2011, 12:52 PM
MiguelsC2
MiguelsC2's Avatar
St. Jude Donor '10-'12-'13
Welcome to the Forum! Your in the right place.
Old 11-15-2011, 02:45 AM
K5kaos
K5kaos's Avatar
Thanks 1sttexan!
I agree.
I've always enjoyed the wealth of info on this site!
Old 11-15-2011, 02:52 AM
K5kaos
K5kaos's Avatar
JohnZ,
As you stated in an earlier post, there is a P-code on the side of the muncie 4-speed in my car.
It is: P8T18
If I understand it correctly that means it was built on December 18th,
1967 , for a 1968 car.
Still not sure if it is a M20, M21 or M22.
Old 11-15-2011, 11:18 AM
JohnZ
JohnZ's Avatar
Originally Posted by K5kaos
JohnZ,
It is: P8T18
That's correct. Pulling the side cover and looking at the helix angle of the gears is the sure-fire way to tell, but it's highly unlikely that it's an M22. If the rpm drop from 3-4 is the same as it is from 1-2 and 2-3, it's an M21; if the rpm drop from 3-4 is much greater than it is from 1-2 and 2-3, it's an M20.
To 64 Diff. Code?
Quick Reply: 64 Diff. Code?
