Replace throw-out bearing...Tremec
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
The throw-out bearing that came with my new Tremec 5-speed for the '64 is bad, so I need to replace it - after maybe, 300 miles. (Of course, I couldn't hear it until I had the body back on and started actually shifting the car.) I hate this, everything is brand new with no scratches - yet...
I know the Tremec is larger than the Muncie, so will it be easier for me to pull the engine and leave the transmission in the car, or will I need to pull the transmission, too?
Thx,
Dave
Thx,
Dave
I would probably pull both. I think it would be easier to mate them together out of the car.
I wonder how the bearing got bad after only 300 miles?
Gerry
Gerry
Thx,
Dave
Thx,
Dave
I supported the bell housing (muncie) with wood, removed the radiator and I could spin the engine in any direction after it was pulled.
So if it were me, I would leave the transmission in. Just use an engine leveler on your hoist.
You will need a clutch plate alignment spline if you put too much weight on the clutch plate as you drag it out but I have pulled many an engine without transmission.. you may need to wobble the engine a bit to get it in
Thx,
Dave
Thx,
Dave
all you need is for the mill to go forward and not all the way out, leave the tko in the car
this is how i do bb's, so a sb should have more room
I've been pondering that myself. I think it's because I painted the engine Ford Red. Though, when the clutch pedal is pushed down, the t/o bearing chirps like crazy - only when pushing on the clutch pedal.
Thanks for the input guys. I'm going to try the side approach, though I'll remove the hood.
