What to use to clean the inside of the rear differential?
I have a 65 with posi rearend. I have the differential mounted on an engine stand to inspect , clean and paint. I didn't have any problems with this so I don't plan on tearing into it. I would like to clean it and inspect the inside. What can I pour in or spray into it to clean out the oil for better inspection?
Thanks Brian
Thanks Brian
Atf
Do this for a few minutes , to clean all the disks in Posi pak
Drain, fill with gear oil. drive for a little while
Drain and fill with gear oil and additive for posi
Forget about for at least 10,000 to 20,000 miles
Jack
