Wheel and Tire Experts Best 17" Combo?
Received 2,112 Likes
I'm thinking of putting some 17" AR TTs on my 65 Coupe.
Can I go 17 x 8 on the rears and 17 x 7 on the front?
Backspacing?
Tire Sizes? I'm looking at 255/40ZR17 rear and and 225/45RZR17 on the front.
Any body running 17s?
Backspacing?
I have 17x7 4 inch backspace with 235 in rear but do have off set trailing arms and coil overs. With that set up 8 inch rim with 245 would fit as well.
Thats what I am running. Except 55 series (I didn't want any less sidewall than I had to). No room for more unless you go with more backspacing. I think the most you can go there is 5 inches. Then you get trailing arm and spring interference.
I've got 17x8 with 285/40s on the rear and 17x7 with 255/45s on the front. Fronts fit with no mods needed at all and don't hit/rub anywhere. Pretty sure the rears would fit with offset arms, but since I've gone solid axle and had the frame narrowed an inch on each side, I can't confirm that. My wheel tubs have not been modified at all.
Pics Pleeeze!
I think with 8"s on the rear you can get away with a 4.25 -4.5 BS.
They are TTIIs 17x7 4 inch backspace and 225/55 Goodyears.
That setup gives you a factory tire circumference. No speedo gear change.
Diablo427 (12-23-2021)
Do you think you could get away with another .25 inch BS front and rear?
Im still running stock 205/75/15s....
FWIW, the rears MAY be 9s, but no way wider than that. I know for a fact that they're not 10s.
Premium Supporting Vendor
Here are a few for you...
My Red 64 Coupe, my Dad's 65 Vert
17x7 4 BS, 225/50VR17
