'61 Heater Hose - Page 2 - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations Sponsored by
Flaming River
Industries
'61 Heater Hose
Old 02-04-2012, 09:07 AM   #21
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Quote:
Originally Posted by Frankie the Fink View Post
Sounds right - that is what Zip shows in their catalog on-line. I'm assuming my copper elbow is OK so I didn't order it. Also assuming the heater control valve is good but I'll examine it when I get under there....we'll see...
ya know, if i didn't care about original (and i don't....); i'd take Doug's suggestion one step further and fabricate a one piece copper tubing section that includes not only the original bend but would continue up and through the firewall. that would make that whole in-car section leakproof. something similar could be done to the other hose section.
Bill
wmf62 is offline   Reply With Quote
Old 02-04-2012, 09:09 AM   #22
Frankie the Fink
Hobbyist..
Support Corvetteforum!
Frankie the Fink's Avatar
Not trying to re-engineer it just don't need a dump out of coolant on those hot Orlando July days in traffic...
Frankie the Fink is online now   Reply With Quote
Old 02-04-2012, 09:15 AM   #23
wmf62
CF Senior Member
St. Jude Donor '07
wmf62's Avatar
Frank
you're no fun.....
Bill
Old 02-04-2012, 09:19 AM   #24
tach drive 61
CF Senior Member
tach drive 61's Avatar
Thanks folks -- not my first rodeo. This is a good job for the frigid Florida February weather. If I can stand to work in the 72 degree garage...brrr..
today i brave my 42 degree garage northern heat wave ! oil/change and valve adjustment !
tach drive 61 is offline   Reply With Quote
Old 02-04-2012, 12:03 PM   #25
AZDoug
CF Senior Member
AZDoug's Avatar
Ya, know, those heater control valves aren't all THAT expensive, and if they leak, they will must likely leak at the plunger rod seal, so iffn it was me, i would replace the damn thing as long as you are under there.
Ain't no fun working under there, and coolant all over your new carpet is a real bummer, and a (most likely) 51 YO part with a rubber seal is waiting for the right time, or jostling, to fail.
I do like Bills idea about a complete copper Ell thru the firewall. Only reason GM didn't do that was rubber hose was cheaper than an extra 6" of copper pipe.
Doug
AZDoug is offline   Reply With Quote
Old 02-04-2012, 12:05 PM   #26
corvette-62
CF Senior Member
corvette-62's Avatar
Quote:
Originally Posted by wmf62 View Post
WOW... i see a cardboard distribution box.... i can't believe they did that as OEM...
Bill
But some how it looks smaller than the one on my '62.
corvette-62 is offline   Reply With Quote
Old 02-04-2012, 12:21 PM   #27
mike coletta
CF Senior Member
Frank.......replace it, and that's all I'm gonna say!!
Mike Coletta
mike coletta is offline   Reply With Quote
Old 02-04-2012, 01:01 PM   #28
62Jeff
62Jeff's Avatar
Quote:
It's a reproduction part from some time in the mid 1980s. I had a metal box on there until the cardboard ones were available. I installed it before taking the car to Bloomington in 1990. I can't say how accurate the cardboard one is, but I do remember it being much more expensive than the more durable but incorrect metal box.
62Jeff is offline   Reply With Quote
Old 02-04-2012, 02:53 PM   #29
Frankie the Fink
Hobbyist..
Quote:
Mike Coletta
I think you know by now Mike that if you say to do it...I d@mn sure usually do it...or else I seem to always regret it later on !
Heater control valve has been ordered !
Old 02-04-2012, 05:42 PM   #30
Redbird
CF Senior Member
C2 of Month Finalist 2016
Redbird's Avatar
Cardboard was the real deal on the heater. Early 62 #0029.
Redbird is offline   Reply With Quote
Old 02-04-2012, 05:57 PM   #31
Ironcross
CF Senior Member
Ironcross's Avatar
Default Zip M-2400
Quote:
Originally Posted by 1snake View Post
Zip -#M-2400, Corvette Central - #451017, Dr. Rebuild - #8850115, Paragon - #575, Eklers - #58199 and on and on.
I guess they're smarter than you think.
Jim
M2400 is just a 90 degree elbow, not what or even close...... a ordinary by-pass hose......and at 10 bucks is a joke.....you didn`t read my reply very well....the Gates hose has the elbow molded into it and at lengths up to 48 inches long...not a small by-pass hose...appears to be a 396/427 hose......
you have to do better than that an on an on......do you have another example....or maybe the customers are the ones not smart to pay 10 bucks for a by-pass hose and then shipping....... Get Gates on line,,,,
Ironcross is offline   Reply With Quote
Old 02-04-2012, 06:09 PM   #32
1snake
CF Senior Member
1snake's Avatar
In your original post you stated "I dont think the Corvette parts stores are smart enough to have them".
I was merely pointing out that they all have them. That is all.
Jim
1snake is offline   Reply With Quote
Old 03-30-2012, 10:13 AM   #33
Steve59
CF Senior Member
Steve59's Avatar
I know that this post is a little old, but I just did my heater hoses on my 59 and it seems that the hoses are much longer than needed, Maybe 6" to 12" to long (at least the 3/4 return). Frank did you have to cut yours down or did you just kind of let them hang by the inner fender?
Steve59 is offline   Reply With Quote
Old 03-30-2012, 04:51 PM   #34
Frankie the Fink
Hobbyist..
Yes my 'correct' hoses were a little long...however they shouldn't be 'hanging' anywhere .. there is a double bracket that holds them up under the passenger side of the engine compartment on the fender and they then go from the firewall through the inner fender clamp on to another clamp up under the generator to the engine...not much slack for anything to hang at all.
i also put TWO cut off valves in the heater hoses under the passenger fender and cut them OFF last week and even with the climbing Orlando temps I swear the car runs noticeably cooler and the cockpit as well. Maybe I'm on to something here...
Old 03-30-2012, 05:41 PM   #35
Redbird
CF Senior Member
Redbird's Avatar
I think the extra foot was for the pump to the expansion tank. Hope these photos help off my 62.
Old 03-30-2012, 06:07 PM   #36
Steve59
CF Senior Member
Steve59's Avatar
That's pretty much the way mine are routed. From the firewall, through the double clip under the passenger side fender, down kinda under the generator, through another oval type clip and then to the respective nipples. My 3/4 hose was about 6 inches too long and caused a crimp at the motor mount (or hung down and would ride on the ignition shielding wing nut), the 5/8 hose was about 2 inches too long and hit the generator bracket. Had to cut both to fit. Looks pretty good now.
However, next question. I tried to save the heater control valve, it's original and has the capillary tube. It leaks. I did buy a replacement valve but it looks significantly different. I'll use the new one if I have to, but does anyone know if the old valves can be repaired and if so, who repairs them?
Old 03-30-2012, 06:57 PM   #37
Frankie the Fink
Hobbyist..
I don't think you'll find a soul that repairs those...as the capillary tube was eliminated w-a-y back and is not a recent thing with the current repro parts. It just didn't do anything significant. Put the new valve in and keep on truckin.... If its really buggin' ya...you could take a run by Tom DeWitt on here...if he doesn't know anybody then it just ain't gonna happen.
Redbird - we need to talk about your engine bay....I've got some extra GM orange spray paint if you need it!
Old 03-31-2012, 09:47 AM   #38
Steve59
CF Senior Member
Steve59's Avatar
Frank:
Appreciate the info. A guy on the NCRS forum gave me the name of a guy who sells them on Ebay. I took a look at the pic of the item he sells and the valve looks like the one I bought from CC with the capillary attached. My original (I believe), looks different. It's not black and the cable attachment is sorta round and not square like the repro, also, the capillary is much bigger.
In any event, decided to use the "new" one. Will keep the original and hope some day to find a rebuilder. Thanks again.
Steve
Old 03-31-2012, 11:04 AM   #39
1snake
CF Senior Member
1snake's Avatar
The cockpit may be cooler but if there's any difference in engine temp., it will be higher with them closed as the heater core is nothing more than an additional radiator. That heat has to go somewhere, cockpit or engine. Your choice.
Jim
Old 03-31-2012, 05:26 PM   #40
Redbird
CF Senior Member
Redbird's Avatar
Frankie, Can't touch much in the engine bay. Car will be taken to San Diego in June for Star Bowtie judging.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • '61 Heater Hose
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    05 heater hose issue turbo2001 C6 Corvette General Discussion 2 05-24-2014 11:45 PM
    '61 Heater Hose Routing johngammel C1 & C2 Corvettes 2 03-10-2014 06:30 PM
    '61 Lower Radiator Hose Frankie the Fink C1 & C2 Corvettes 40 02-16-2012 04:12 PM
    1961 Corvette Heater Core Bypass 21Vette99 C1 & C2 Corvettes 5 03-14-2011 02:21 PM
    Heater Hose sizes (dumb question) y5e06 C4 Tech/Performance 9 03-23-2004 10:56 PM
    Tags
    applying, engine, glue, gorilla, heater, hose, last, long, monkey, snot
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
