Suggestions for 63 alignment specs?
Old 03-15-2012, 03:33 PM
jimdvan
Default Suggestions for 63 alignment specs?
I have a 63 vert with stock front end and Flaming River 12:1 steering box. All parts have no more than about 5K-8K miles on them. It has power steering. The tires are BFG 215/65/15 T/A radials.
I have the steering box set-up with virtually no play in the steering just short of tight. Upon turning right or left on curves or actual turns the steering return-to-center is a little sluggish and not quite complete. The car is due for an alignment and I would like a little quicker return-to-center response if I can get it. I also like neutral steering with no compensation for road crown. Any suggestions on how to have the shop set it up?
Old 03-15-2012, 03:59 PM
BarryK
BarryK's Avatar
C2 alignment with radial tires - info from JohnZ from prior postings:
http://www.lbfun.com/warehouse/tech_...0Alignment.pdf
Old 03-15-2012, 05:05 PM
jimdvan
Old 03-15-2012, 05:53 PM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
I don't know what a Flaming River steering box is but if you have it set up "tight", especially if it has used parts in it, that may be part of your sluggish return.
Make sure you have enough positve caster in the alignment to return the wheels to center but not enough to cause hard low speed steering.
Old 03-15-2012, 08:23 PM
jimdvan
Flaming River makes a repro GM steering box. It was brand new with new parts. If I have the lash adjustment any looser it will wander too much. Its not tight enough to bind and the steering return was a little sluggish anyway for my liking.
Old 03-15-2012, 08:31 PM
MikeM
MikeM's Avatar
If you don't have enough caster dialed in, it will wander and be slow to return regardless of how tight your steering box is..
Old 04-17-2012, 01:52 PM
jimdvan
I had the alignment done with the recommended specs but I think something is amiss. At 50-70 mph if I hit the gas hard the car wants to drift left. When I let off the gas it comes back to the right. My guess is it isn't supposed to do that.
Old 04-17-2012, 02:32 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
That's a classic symptom of a rear toe-in problem; either the rear toe-in isn't equal across the thrust centerline (biased to one side), or front trailing arm bushings are loose, or both.
Old 04-17-2012, 03:09 PM
jimdvan
Thanks. I'll take it back and have them recheck it.
To Suggestions for 63 alignment specs?
Quick Reply: Suggestions for 63 alignment specs?
