Is there a secret to removing C2 vent weatherstrip?
It appears the only way to install the weatherstripping on a C2 vent window is to remove the vent window from the outer vent window frame.
Have I got this correct?
What's the preferred method of removing the vent window from it's outer frame? I am inclined to remove the two rivets that hold the pivot hinge to the outer vent frame.
I removed and replaced the rivet, but I was doing a complete paint and removed and replaced all window glass, weatherstrip, etc.
I think you're talking about a convertible, which is correct. On a coupe as I'm recalling, I think you have to remove the single rivet at the upper part of the vent window pivot, then replace once the weatherstrip is installed. I'm also recalling that some folks have cut through one side of the new weatherstrip where the shaft on the vent window passes through in order to avoid removing and replacing the rivet. Not sure how this has worked out, maybe somebody will give you some information on this procedure.
Jim
Okay, thanks guys. Just wanted to be sure before I did anything rash (and unnecessary).
Looks like invasive procedures are required, as I am dealing with a coupe and not a convertible.
I think the idea of cutting the weatherstripping defeats why I am replacing it in the first place, so I'll be going the rivet route.
complete weatherstrip install first, then hinge pivot install
to
partial weatherstrip install (at T bar end) , hinge pivot install, then balance of weatherstrip install
Do it the right way
While it's very tempting to install the W/S by cutting it, the right way is to pull the vent window assembly and drill out the pivot rivet. That piece of W/S is $30 to $40 and it seems silly to cut it up instead of taking the extra time to do it right.
I didn't know whether I wanted to chance replacing the hinge pivot rivet or take the easier route and replace the two rivets that hold the hinge mechanism to the frame, but Corvette Central made that decision for me, since the hinge pivot rivet (CC part # 282216)is on back order until April 10th.
Rather than going with a conventional rivet, as Jim suggested, to hold the hinge to the frame (2 rivets required), I decided to go with the rivets that are available as a pair that hold the T bar to the frame (CC part # 282137), to adhere to originality.
This way I can avoid buying the fancy (one use for me) rivet tool pictured above, since the rivets are not visible.
Jim
OK, I'm one of those great offenders who cut the weatherstrip. Cut it open at the hole for the hinge pin with a razor blade. Put it back together with weatherstrip adhesive after it was installed. Is it perfect? No, but you have to look close to tell that it's been messed with. And my car is far from NCRS or show or any of that.
Do it as you please, but I'd rather do the hinge rivet, they're available from several sources other than CC. You really don't need the tool to set the rivet, it's not a solid shank rivet as I'm recalling. I think the ones I procured had a hollow end, and I used either a B-B (yes, from a BB gun) or a small ball bearing from somewhere. Placed the ball (or BB) on the hollow end of the rivet and used a pair of Vice Grip pliers to upset the hollow end of the rivet. Use a couple layers of tape on the flat head of the rivet to keep from marring or scratching it. Worked like a charm, can't tell it from the factory one I removed.
Here's the hinge rivet. No doubt it is hollow on the left hand side in the picture below:
Received 1,857 Likes
