1957 Inner Door Reinforcement - Help!
I just found out some bad news today, my 57 is at the body shop getting prepped for paint. Upon fitting door posts to the car, it was discovered that the inner door reinforcements are missing from the drivers door. The AIM shows three part numbers on Section F, Sheet 14.00
LH 3749249
LH 3749253
LH 3749259
The three reinforcement pieces rivet inside the door.
I have included a photo of the right hand side reinforcement from inside the door, looking from the rear of the car forward.
Are these parts reproduced? If so, where are they available? I am hoping that someone can point me in the right direction. If they are not reproduced, I will post a parts wanted ad (moderator, please excuse me), but hoping someone can help. Does someone have a damaged door available? Are the later model 58-61 doors compatible, or do I need to stick with the 56-57 doors?
Ideally, I would like to locate the reinforcements and rivet in place on door that I have, as the fit to the body is fantastic.
Hoping someone on the forum can help
Regards,
black1961
LH 3749249
LH 3749253
LH 3749259
Regards,
black1961
LH 3749249
LH 3749253
LH 3749259
Regards,
black1961
LH 3749249
LH 3749253
LH 3749259
Regards,
black1961
I visited with a 56 owner at the Lawrence, KS swap meet last weekend and he said the same thing about the 56 doors. My car is an early 57, with an assembly date in Dec 56. In the AIM drawing, the door post bolts to the inner reinforcement. What does the door post attach to without the reinforcement pieces? I would feel better with the inner reinforcements pieces in place... so would the body man! The passenger door has the reinforcement pieces riveted in place. Can't swear that the passenger door is original to the car, but the door post is bolted firmly in place. Would like to locate the parts and fix this now. I have about 30 days before it would hold up my schedule with the paint booth. Regards, black1961
if you believe teh assembly manual,,, i guess the passenger door isn't original, as 12/56 is before they were installed...
Received 1,857 Likes
knockbill & JohnZ,
Thanks for the replys about the early 57 doors, I'll pass along the information to the bodyshop.
Will post photos of the car later this week. It's coming along nicely, panels aligning well and good gaps on the doors, trunk and decklid. I can't wait to see some color on the car!
Regards,
Black1961
Regards,
Black1961
knockbill & JohnZ,
Regards,
Black1961
Regards,
Black1961
