What year did starters..........
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
....start mounting to the block, and not the bellhousing? Did they still use the bellhousings drilled and tapped for starters after the change over to block mounted?
And it looks like 62 was the last year for it
http://forums.corvetteforum.com/1577739477-post7.html
Received 1,843 Likes
If it had the 153 tooth flywheel, it had the block mounted starter.
The first Chevy engine was the '62 four and six cylinder Chevy II engine.
The first V-8 Chevy engine was the Chevy II dealer V-8 conversion in late 1962.
The first Corvette V-8 would have been the '63 model.
Thanks, now I'm really confused! My 62 has the original motor, and the block mounted starter has been on since way before 77, when I replaced the block mounted starter in Californa, but when I was changing the solenoid today I noticed the bolt holes in the bell housing?
What's up with that?
St. Jude Donor '07
typically a block mounted starter nose will not fit into the hole in a bellhousing mounted starter bellhousing. i had to knock the corner off my bellhousing in order to use a block mounted one.
Bill
Bill
I think it was Tom Parson that stated that a cast iron nose on a block mounted starter will fit into the belll housing starter hole (with the bell housing mount & holes).
John
Received 1,724 Likes
2018 C1 of Year Finalist
62 4 speed mounts to bellhousing.
Received 3,768 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
FIRST OF ALL, WE'RE ONLY TALKING MANUAL TRANNY SETUPS AND GM-DELCO STYLE STARTERS BELOW!
For the smaller, 153 teeth flywheel (REMEMBER, starters must be matched to BOTH flywheel size AND bell housing style), ALLLLLLLLLLLLLLL starters were block mounted. Period!
For the larger 168 teeth flywheel, there are some options.
IF a bell housing is used with the 3 holes for mounting the starter to the housing, then either a housing mount starter can be used, OR, a block mounted starter with a staggered bolt pattern and a CAST IRON NOSE. Repeat, CAST IRON NOSE! YES, a starter with a staggered bolt pattern and an ALUM nose and one with a CAST IRON nose are different!!!! The alum nose is "fatter" and will not fit into the starter bulge of the big bell housing. When using a block mounted cast iron starter with the 55-62 style bell housing, it MAY be necessary to do some VERY MINOR trimming of the starter nose. But the alum nose is a no go, period. PLEASE, do not modify the bell housing to make a block mounted starter fit-----------------ESPECIALLY A 60-62 STYLE ALUM BELL HOUSING!!!!!!!!!
For a 63-later BIG bell housing, such as a 942, 983, 444, 621 or even a truck housing (to fit the 168 teeth flywheel), a block mounted starter with a staggered bolt pattern and CAST IRON nose is the ONLY choice.
MOST starters that I have seen with the staggered bolt pattern and a cast iron nose were the hi-torque variety.
MOST starters with the straight bolt pattern and alum nose (I've NEVER seen a cast iron nose with a straight bolt pattern) were the standard torque variety. BUT, there certainly were hi-torque starters with the straight bolt pattern (used on MANY hipo small blocks).
Tom Parsons
Tom Parsons
Tom Parsons
Tom Parsons
Received 1,857 Likes
In Corvettes, the '62 Powerglide was the first usage of the block-mounted starter; '62 manuals still used the bellhousing-mounted starter. From '63-up, all Corvettes used block-mounted starters.
I wondered this, because the housing holes have been used before from the look of them, and the bolts holding the starter to the block are not starter bolts, you know... the knurled ones with the shoulder, they are regular bolts with lock washers, and shorter than the regular ones. Mystery solved....I think. Thanks.
St. Jude Donor '07
Ya, forgot there are three, my mistake. So basically in 62, you can use either type of starter, block or housing mounted.
Bill
All of the '55-'62 large-flywheel bellhousings have three tapped holes for the three horizontal starter attaching bolts; the one in the photos above has the bottom corner broken off through the bottom starter bolt hole. Photo below shows the three starter bolt holes.
