1966 Fuel Pump Replacement
I replaced my 1966 350 hp 327 with a 400 + hp 383 with roller cam and rockers. Stopped at parts house today as I wanted to replace fuel pump. Found all kinds of listings. 300hp 327 one pump, 350hp 327 different pump, 67 327's different pumps.....what pump should I buy...do not want to go electric. My block is a 1973 with dipstick on drivers side.
Dr. Detroit
Received 3,891 Likes
Jebby
Received 2,126 Likes
It might be a factor. What carb are you using? Dennis
The position of the fuel inlet and outlets at the fuel pump seem to be the largest discriminator in whether or not a pump will fit.
If your fuel lines are still oriented the same as with your stock 327/350 engine, get a pump for that.
This may help you out. I swapped my 327 for a GMPP crate zz383. We used a Holley fuel pump #12-834.
http://www.jegs.com/i/Holley/510/12-...FQlN4AodgFzAkA
Dennis
Dennis
Dennis
Dr. Detroit
The orientation of the pump that Mr. beck posts is very close to the orientation of the 300hp pump.....The 350 horse has them split almost 180 degrees of each other.....and it made it much easier to plumb the inlet and outlet in a straight shot.....I wasn't real hot on using a brass 90 degree fitting due to the restriction.
It is not to say the one he suggested will not work...I am just picky.
I will post a photo and get you a part # when i get home if you are interested.
Jebby
Jebby
I purchased the Holly fuel pump and it had almost identical outlets for my fuel lines. Works great and gives me more volume of fuel. Thanks for all the help and advice.
