how to stop sun visor droop
My Driver's side sun visor keeps falling down. I tightened the screws to the point that the screw tip came out the other side. I ran a small bolt/nut through but still falls down. I need to move it when I take the top down. Any suggestions?
What year ? My '61 has tension screws at each end of the visor that I occasionally have to snug up...
I had a droppy visor on my 1967, and was able to cure it by taking the fastening screws out, cleaning and oiling the threads, and then putting them back and tightening everything securely. If this doesn't work, I'm not certain of any additional fix except visor replacements or perhaps buying/trying a new visor mounting kit. LICS sells these kits, but other suppliers may also have them. LICS #10-17.
Larry
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
I had the same problem on my '64. I did purchase new sun visor hardware, but that in itself didn't solve the problem. I then, carefully, squeezed the portion of the sun visor (it's metal inside), where the pin goes in. I haven't had any problems since then.
St. Jude Donor '05, '09, '15
I fought this for years. Put on new sun visors and new hardware kit. Good for a while but eventually started doing it gain. I found one solution that resolved the issue. I took them off.
Tom
Tom
With the top down, its easy. Just take the outer edge of your visor out to where you can squeeze it to sit on top of the female soft top mounting latch. My dad did it while riding shotgun in my car, and I thought it was brilliant. With the top up, however (???)
I did the same thing, but with a rag over the area where the pin fits, I gently tapped it closed tighter with a small hammer. (While lying flat on my work bench) havn't had a problem since either
redstar (06-09-2020)
...and spend the money you would have spent on replacement visors on a good pair of RayBans..
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Huh, I'm sure I read in the oweners manual that that is normal for ALL corvettes!
I don't even think about it anymore, my arm just automatically reaches out and readjusts them after a bump.
There you go. I tried the heat shrink trick, pinching the visors at the mounts, even pulled the mount pins and used a center pinch to try and rough the surface of the pins. All were only temporary for me. I'm glad allot you guys had better luck. For the 15-20 deg of operational coverage it wasn't worth it anymore.
Easy fix from the old days: Remove visors. Pull chrome prongs from ends. Cut some 7/32” aluminum tubing about 1-1/4” long and insert into the ends of the sun visor. Reinsert chrome prongs. Reinstall visors. This will last several years, depending on how much you use the car. Cut several extra pieces of aluminum tubing for future use. Use needle nose pliers to remove worn out aluminum tubing when visors start flopping again.
Lou
Lou
The following 3 users liked this post by LouieM:
Lou
Lou
Jack
ps...took them off for 35 years...only last ten...put them back on..one of the joys of ownership...
Lou
Lou
Received 1,919 Likes
Total cost: pocket change for the tubing, trip to the hardware store, and 20 minutes installing the tubing. Works like a total charm, no slips, not too tight, not too loose. I used brass, too.
I love it when a simple and elegant solution fixes an outsized aggravation.
Should all C2 fixes be this simple.
