Starter Solenoid Purple Wire
Old 06-02-2012, 10:39 PM
Reeltales
Reeltales's Avatar
Default Starter Solenoid Purple Wire
I have a 67 with a small block. With respect to the purple and pink wires, which connect to the solenoid, Which one connects to the terminal on the block side and which goes to the outside terminal?
Also, with and HEI distributor, do you need the ballast resistor or can you wire from ignition switch to the Distributor direct?
Old 06-02-2012, 10:48 PM
6T5RUSH
Support Corvetteforum!
6T5RUSH's Avatar
Cruise-In III Veteran
Although mine's a '65, they may be identical for this.
Here's a couple of pics of the wiring that may help you.
Good luck!
Jim
In God We Trust!
Old 06-02-2012, 10:57 PM
Reeltales
Reeltales's Avatar
Looks like purple goes on the terminal closest to the block. I think I wired mine backwards which may be why I get nothing when trying to start the car..
Old 06-02-2012, 11:06 PM
65GGvert
65GGvert's Avatar
Received 3,205 Likes on 2,297 Posts
If you can see it, the purple goes to the terminal marked "S" and the pink to "R"
Old 06-02-2012, 11:18 PM
Reeltales
Reeltales's Avatar
Just swapped the wires and bingo...... I still would like to know if with the HEI distributor, do you need to run through a ballist resistor.
Old 06-02-2012, 11:19 PM
Reeltales
Reeltales's Avatar
Jim, thanks for the pics....
Old 06-03-2012, 02:48 AM
AZDoug
AZDoug's Avatar
Received 1,477 Likes on 904 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
The ballast is coil specific, the points or HEI just tell the coil when to fire.
Doug
Old 06-03-2012, 07:27 AM
knockbill
knockbill's Avatar
i put a gm hei in my 68,,, i eliminated teh "resistor wire" that went to teh points distributor, and ran a 12 gauge wire directly to the dist from teh ignition tab on teh fuse box,, easy and neat....
Old 06-03-2012, 08:05 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Bypass the resistor. 12v to the HEI.
Old 06-03-2012, 08:16 AM
BADBIRDCAGE
BADBIRDCAGE's Avatar
Received 1,963 Likes on 1,055 Posts
I went one step further and ran 12 volts fused from the battery to the HEI through a relay. Now I use the ignition switch feed to power/excite the relay.
To Starter Solenoid Purple Wire
Quick Reply: Starter Solenoid Purple Wire
