S-10 spare tire
S-10 spare tire
I know this subject has been beat to death but I forgot the size and years for the S-10 space saver spare tire. Can someone help me out?
I figure I better do something before I have a problem.
uniroyal hideaway tire & rim T I 35 170R 15-99
Will this 5 hole pattern on rim fit original rim on my 63swc? I t may be smaller than S-10 but can it be used temp if bolt pattern fits? Regards, Abe G
Has to be the GM 4-3/4" bolt pattern and you can pretty much 'limp home' on anything that will mount and not rub. However, putting a different diameter tire on a rear axle with posi-traction is bad news. The differential will think the car is in a constant turn and wear out components pretty quickly. You can swap a front tire to the rear and put the smaller spare on the front in such a case.
I have to do just the opposite my HHR SS. The brakes are too big on the front to use the spare,plus posi.
Spare tire size that fits perfectly on a '66 is a Chevy S-10 Pickup 1995-1999 economy spare tire size T155 / 90 D16. Clears the manual calipers just fine. Fits inside the spare tire compartment perfect. Good luck.
Kevin
Kevin
http://www.robertson-tire.com/showca...tm?ID=16992719
Also found one on Amazon for $266.52!
http://www.amazon.com/GOODYEAR-81837.../dp/B006X1SNRC
Plasticman
Are the RIMS all the same on the S10's? Dia/width regardless of year?
And what size are they?
uniroyal hideaway tire & rim T I 35 170 R 15-99
Can anyone tell me if the above specs will fit the hub of my 63 swc? I know this is smaller than the scout but would appreciate any advice. Regards,. Abe G/ PS Thanks to Frankie and others re advice on positraction, saves a headache!
Make sure you fully inflate the spare to designated pressure or it will not reach desired diameter.
1982-2004 Chevrolet S10/GMC S15 and Sonoma 1983-2005 Chevrolet S10 Blazer/GMC S15 Jimmy
I would look for the S-10 Blazer or S-15 Jimmy temp. spare, since they would of been inside the cabin, and covered.
Plasticman
According to LMC (parts supplier), the following years apply:
Plasticman
Plasticman
My 89 S-10 Blazer 4WD had a full size spare hanging on the rear (not underneath).
But our 99 S-15 4WD Jimmy had a temp. spare inside (the one Barb rolled on I-75).
S-10 Blazer and the S-15 Jimmy are essentially the same vehicle.
And yes, full size Blazers (I have had 2 as well) and S-10 Blazers are completely different animals. Same thing with the Jimmy and the S-15 Jimmy being completely different.
John
