How much hp with this build ?
Old 07-11-2012, 06:06 AM
fishinfever
Cruising
fishinfever's Avatar
Default How much hp with this build ?
• 540 CID
• World Products 4.500 Bore Blocks
• Brodex CNC 2X plus heads
• Scat super Lite Billet crank 4.250 stroke
• Scat H-Bead 6.585 rods
• J&E 11.2 to 1 F-pistons
• Crane roller cam and valve train 260 dur. 640 lift
• Weiand X manifold
• Holley 4150 1000CFM carb
• Holly electric fuel pump
• B&M oil cooler
• Oil pan 8 ½ quart
• Melling H - V oil pump
• Mallory unilite distributor
• 3:55 gears and pose rear end
• Hooker Headers into side exhaust
• Gymkhana (road race) Front and Rear springs
• KYB shocks
• Completely rebuilt suspension
• Fully adjustable rear alignment
• All hoses are braided steel
• Braided brake lines
• Power brakes
• Power steering
• 4 W.P.D.B vented and drilled rotors
• New gas tank
• 4-speed Muncie Transmission
• All new clutch, flywheel, throwout bearing new in 2009
• Aluminum Be Cool Radiator
• Electric Radiator Fan
• Aluminum water pump
• All engine bolts ARP
Old 07-11-2012, 06:41 PM
steampunk c1
steampunk c1's Avatar
To much for stock frame and tyres 650 700 rear wheels hp????
Old 07-12-2012, 05:26 AM
fishinfever
Cruising
Thanks for the reply.
I was told the build was close to 800 hp. It was built out west and I can't get ahold of builder, he has move on from the shop and no knows where he ended up. Just wanted to know more about the car.
To How much hp with this build ?
Quick Reply: How much hp with this build ?
