F41 Special Front and Rear Suspension
Old 07-11-2012, 10:23 AM
Kuhn
Kuhn's Avatar
Default F41 Special Front and Rear Suspension
On the 67 corvette they offered the option F41 front and rear suspension. How was this (F41) different from the factory stock suspension?
Thanks!
Old 07-11-2012, 10:41 AM
Mossy66
Mossy66's Avatar
St. Jude Donor '14
A quick search found this:
http://forums.corvetteforum.com/c1-a...uspension.html
http://forums.corvetteforum.com/c1-a...af-spring.html
http://forums.corvetteforum.com/c1-a...ifference.html
And maybe a dozen more threads.
Gerry
Old 07-11-2012, 10:55 AM
66since71
66since71's Avatar
Thanks!
Springs, shocks (including lower rear shock mounts) and front sway bar (including it's bushings)
Harry
Old 07-11-2012, 12:50 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Was this option only offered on the Big Blocks in 1967?
Thanks!
Yes - in '67, it was only available on L-71 and L-88.
Old 07-11-2012, 12:53 PM
vintagecorvette
vintagecorvette's Avatar
How about L89?
Old 07-11-2012, 12:57 PM
JohnZ
JohnZ's Avatar
Originally Posted by vintagecorvette
How about L89?
Yes. L-89 was an option on top of L-71.
Old 07-11-2012, 12:58 PM
vintagecorvette
Thanks for the info.
Old 07-11-2012, 04:33 PM
SupremeDeluxe
SupremeDeluxe's Avatar
2015 C2 of Year Finalist
Learn something new about these cars all the time....I just replaced mine (factory F-41 L-71) and did not realize there were two different lower mounts. I probably installed the incorrect ones.....
Old 07-11-2012, 05:25 PM
66since71
66since71's Avatar
No big deal, they interchange both ways. One of the links in post #2 shows the difference. One is just beefier than the other.
(a John Z pic of course!)
Harry
Old 07-12-2012, 12:46 PM
JohnZ
JohnZ's Avatar
Harry
The F41 rear shock mounts also move the bottom end of the shock inboard about another 1/4" to maintain clearance from the larger-diameter F41 shock body to the spindle support.
Old 07-12-2012, 01:00 PM
SupremeDeluxe
It is VERY close quarters with the F-41 shocks. Paragon only lists one P/N for each side, and those are the ones I installed (I buy everything from Paragon). I'd need to look back and see if the ones I removed were originals with any markings to identify them.
Old 07-12-2012, 05:41 PM
chrislyn
chrislyn's Avatar
Default Shock mounts
Original lower F41 shock mounts are part # 3829265 / 3829266 and the numbers are on the side of the mount.Wes
To F41 Special Front and Rear Suspension
Quick Reply: F41 Special Front and Rear Suspension
