If you have a c2 and TKO please help me out doing the install, is this right?
looking for a pic of the shifter, installed. or an interior shot that shows the shifter. My base is too tall to use the stock boot, that seems wrong...is it? if so what have you guys done for boots? c5 boots? Thanks, I did a search, nothing answered what I was looking for...
David
You just need to bolt the boot down and it will shape around the shifter handle.. Here is from a couple of years ago
Here is another
All of these photos are at least five years old as I haven't had the Tremec in the car for that long... I really need to pull the motor and put it back in...
David
Here is another
David
Hitch,
Did you cut this stick off an old C2 Hurst and drill holes to fit the TKO? I wish Hurst still made that style. Thanks
You probably know this but your shifter design is different than others. Here's a shot of mine. It's from Hurst Driveline and is a TKO600. The boot fits fine.
see, it looks like your shifter is about 1 to 2" shorter than mine, Its a real strech to get it to touch the floor, let alone get it alighned with the metal boot retainer ring. So I think i will need to go the c4 route. will any year c4 boot work? will a c3 boot work?
your shifter is taller than mine.. i orderd my TKO600 a few years ago from classic chevy 5 speed and all the original parts fit - shifter surround / center console / boot(s). IIRC, my shifter doesn't have that machined box above the black plate on yours. I seem to recall my shifter box bolting straight to the side vice down from the top. could take some pics this weekend if you still need it.
IIRC, my Keisler Perfect Fit TKO-600 is also different at the top (was their 2nd design) and doesn't stick up as high. Mine came with a Hurst shifter with the flattened sides, but it doesn't have the bend in it.
well I ordered a 3rd gen camaro shift boot, found the tip on another thread here. I'll let you know how it works out..thanks for the help! and dont let it stop you of posing pics. Could be a usful thread for others, I wish I had one like it to find!
