Al Knock pads vs. Romeo
I’ve read several posts here about the al knock and Romeo dash pads for the 58/62 cars. There is both good and bad feed back for both brands. I’ve installed several al knock pads and always had a lot of trimming work to do. I talked to Romeo about his pads and he said his pads fit great but the problem is you have to install them right away. If you leave them lying around for several weeks they will shrink and will not fit. Since his is half the cost of al’s pads and I’ve never installed one before I believe I will purchase one of his. I would like to have feedback on this subject if you guys are not tired talking about them.
Agree completely. My '61 has the Romeo pad and, although it looks good installed, it was twice as much work. The total length of the pad is too short and the radius of the half-circle around the passenger-side dash insert was inaccurate. I had to compensate for both shortcomings during the install. And pls note, I installed the pad withing 72 hours of receiving it.
Several threads on this topic (some by me) are available.
Sounds like a lot of plasticizer (di octyl phthalate, or similar) is being used in their formulation,and as it evaps out, the pad shrinks and probably turns hard.
IMO, anyway.
Doug
Al Knoch used the original tooling that he bought from GM so that should get you as close to original as you can get. That being said, it doesn't mean it will install with not trimming or cussing.
corvette america
I've read that Corvette America has quality pads. They list for 399.00 and right now have a 12% discount sale so I'm thinking about purchasing from them. Al Knock may be the best but I've used them before and I would just like to see how another vendor's pad will work. If it does not fit I will just send it back. thanks everyone
Received 1,843 Likes
I have always wondered if Al's face gets a little red everytime he's sees his name spelled "Knock" instead on "Knoch"?
I just installed a Corvette America pad in a 62 and it fit perfect. The last AK one I did needed alot of the foam trimed out.
That said I think the AK one looks better. The grain looks more correct than the CA one.
C-1 dash pads
I've installed quite a few Knoch dash pads and each one was easier than the last as far as trimming goes. If you talk to Al he will tell you that they are constantly improving them in this area. Personally I'd much rather spend a little time removing extra foam than worrying abot fit and shrinkage issues. I'd use the Al Knoch pad. Rich
