2" side exhaust pipes on 2.5" manifolds?
1964 Corvette 327 CID / 365 HP
Can 2" side exhaust pipes be adjusted to fit 2.5" manifolds? I bought a set and then later learned the engine I have has 2.5 inch exhaust manifolds. Can they be adjusted, or flared to fit? Do I need some kind of adapter? Any help would be appreciated.
Also, are the side covers of different sizes for 2" and 2.5" pipes? Or are they all the same, regardless of these two pipe sizes?
C2 of Year Finalist (appearance mods) 2019
I could be wrong, but I think the flange is the same size on both the 2" and the 2.5". The actual pipe is the only thing that changes.
The side covers are all the same.
The ones I just bought from Allen's have a step down for the 2" manifolds on my '67, I thought All the SB side pipes were 2 1/2" OD?
Are you sure yours are only 2" OD?
Paul
Paul
Received 1,857 Likes
'65 SB sidepipes came two ways - 2" manifold connection or 2-1/2" manifold connection, depending on the engine; '66-'67 SB sidepipes only had one flavor - 2" manifold connection. All sidepipes (SB & BB) used the same straight muffler section (1-7/8" inner pipe diameter).
Is it the L76 engine which had the 2.5" manifold that a 2" pipe connection would not fit? I'm trying to decide if I should make this work somehow, or just sell them.
St. Jude Donor '07
it can be easily made to work, don't fret about what engine had what... as John said:
Bill
Bill
Received 1,843 Likes
I assume it was the L76 365 HP engine that called for the 2.5", and I'm guessing that was necessary because of the higher compression (11:1)?
I believe I would rather have my 2" diameter downstream in the sidepipes as the exhaust cooled and contracted rather than in the hot, expanding, exhaust coming out of the manifold.
JMO. Maybe GM engineers know different?
Can I just bolt these on or do I need some sort of adapter for the pipe to manifold connection. I currently have the regular under car rear pipes install. Before I remove them, I want to make sure this can work.
(btw, the car had small side pipes in the 70's, someone already cut off the body and bracket)
You can probably have a muffler shop cut off about six inches of your pipe and weld on the same length and 2 1/2" diameter connector to your manifolds.
Go see Midas. They can be your friend.
St. Jude Donor '07
Your car does/should have 2 1/2" manifolds. The pipes you bought have 2" inlets. You NEED TO DO SOMETHING here to make them fit.
Bill
