Help removing door lock handle
Well, I just got done polishing all of the brightwork on my 61, went to open the passenger door, and when I pushed the external door latch button, it not only went in, it went completely in, falling into the door cavity.
I'm trying to remove the interior door panel, but can't get the door lock handle off. I don't have the special tool, and don't need it for the window handle (electric windows), but can't figure out how to get the lock handle out of the way. Please help!!
I think I know what you are referring to. Depress the material on the door panel and squeeze a look behind the door lock...you will see a spring clip that holds the lock handle in place..similar to what holds the window handle in place.
Here is a link to the part I am referring to.
http://www.parts123.com/parts123/yb....7M66249718424d ~Z5Z5Z5~Z5Z5Z50000050x
I usually use a small screwdriver to catch the spring clip and pop it off the lock stud.
If you cant catch it with a screwdriver try a piece of an old t-shirt. Put it behind the handle on open side of the clip and work the shirt up and down to catch the clip and pop it off!
Thanks for all your help. I did get it off with a small screwdriver and a paint can opener (used as a hook to grab the top of the ring). Trying to figure out how the door latch goes back together. Will check the assembly manual to figure it out. The maintenance manual pics aren't real good on how it all fits together.
Here is some info that may help you from forum member Dave Zuberer.
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
See Sect. F, page 6.00 in the AIM for the view of the handle and lock. Remove the access panel and use a bright light to pick up any and all pieces that may have fallen to the bottom of the door. May want to use a magnet to check for pieces. Study the AIm closely and take your time. You almost need to reassemble outside the door on your kitchen table to understand how it works. I had one hell of a time when the same thing happened to me.
Thanks again. Between the PDFs and the AIM, I be working to get it back together. That will be tomorrow's learning experience. Being a relative newbie, I'm always amazed at the willingness of forum experts to lend a hand. I'll let you know how I made out.
BTW, Frankie, your car is the same year and colors as mine. Much better looking, and more "civilized" than mine. I believe mine has the original paint. At some point I may be looking at PS, but that will be a ways down the road.
Here is an interesting factoid -- What part of the car has the most pages devoted to it in the 58-62 C1 AIM manuals ? The DOORS !! That should tell you something about what you are getting in to...
While you are into the doors its a good time to replace stuff that might have gone missing over the years. The door handle metal 'backing plate' reinforcements, the small fiber board squares to cover access holes, the large nylon washers under the inside door pulls, window cranks, door locks, the thin black gaskets that go under the exterior chrome door handle, etc..
My car was missing all of that stuff.
BTW - The AIM shows the little spring/washer/cotter key setup on the rod that actuates the door handle TWO different ways -- only one of which will keep it from binding; so watch that. Install it as shown in the 2nd PDF. It will seem wrong when you are doing it -- but it's not.
Finally - look at the other forum thread here: http://forums.corvetteforum.com/c1-a...er-screws.html. If you find a large, funny-looking screw on the back of your door handle this thread will tell you about it.
As far as my car and 'civilized' -- I love it...I have never driven a more streetable muscle car that still is a kick in the pants to drive and with the 5-speed can get 22-24MPG cruising..
Well, I got it done, at least temporarily, and took about 2 hours. I need smaller hands, better glasses, or a bigger access hole. I didn't realize at first that I needed to take the handle off to put everything back together. The "clamshell" affair that holds the latch mechanism on the back of the handle seems to have spread, and I fear that my fix will only last long enough to fail at the most inopportune time. I do need the handle gasket, and some of the other parts replaced, so I will be into all of this again and will have a new handle available then. Try as I might, I couldn't get both washers and the spring on, so that's another reason to get back into it when I have all the parts I will need to fix it right. Seems like a good winter weekend project. I actually have the clutch head drivers as part of a bit set I bought at Carlisle last year. Didn't need them for this project. Clearly, a previous owner was into the door before.
Thanks for all for the pointers and information. You guys are a great resource for us newbies!
Check EBAY. Other vendors have them too.
There are about 5 sizes in a set IIRC.
Chuck
Glenn, you can always count on the guys/gals on this forum to help. Also, thanks for the pdf Frankie, I wish I would have had it two years ago when my door handle button fell into the door after I locked it from the outside. Try reassembling w/o a schematic.
John F
John F
Thanks to Dave Zuberer (DZAuto on the forum), John Hinkley (JohnZ) and many others for the vast technical library of C1 info I've built up over the years !! It's my privilege to share it.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Dug up this thread after wrestling with the exact same problem...
It was me, as a 13 year old kid (in 1978), who pushed the button on the passenger side and had it fall into the door. I still remember how mad my dad was when it happened. So here I am now, 35 years later, paying the price for that mishap!!!
I took apart the door and found the button plus a small square nut in the bottom of the door. But I could not get the mechanism pushed back into place.. After finding this thread, I suspect I need to remove the handle before I do this?
Also - I didn't find a spring inside...??? Should it be there?
Thanks for any help!
Fred
Fred
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Make a tool with a coat hanger. Bend a tiny hook into the end of it, as small as you can make it with pliers, push the panel back and grab the top of the spring clip with the hook and pull. Very easy.
I finally got my door working and back together today! Yea!
The biggest "missing link" for me on this project was how the latch connects to the door handle. Big forehead slap when I finally figured this one.
I could assemble everything fine, but it didn't work because it was just hanging in space. The key is that the latch goes into the button hole, and turns 90 degrees to lock into place. Most of you probably know this... but as someone new to working on these cars and studying the Assembly manual plus the various online help/photos, NOWHERE does it mention or show this "obvious" fact! So I will mention it for any future searchers in the forum.
It was my neighbor with a 57 Chevy who finally revealed this to me.
Thanks all for the input.
Fred
Fred
