Difference between a small block rear and big block rear
For a 67 I would like to know what are the differences. Ive looked and all I could find were the axle stubs.. (caps vs U bolts) Does this mean essentially you can make a big block rear out of a small block with just a stub change?
Well the tapped differential yokes with the bolt on caps is the obvious change, but there also ratio stamps on the differential that would be specific only for a big block car. These would be AT, AU, AZ, FA, FB and FC codes. So a 1967 big block 4:11 rear would have an FB code, but if you have a 1967 corvette 4:11 diff with an AP code, then it came out of a small block car
Yes but that would not affect the performance which is what the OP is referencing..
Received 6,943 Likes
2015 C2 of Year Finalist
what is a devils den color combo? and any 65-79 rears are the same
At least you'll never see this one trying to be sold as a real one.. I know Ill have more money in it than its worth but I could care less about numbers, as long as it looks the part.. Keepin the GF happy is a hard bargain also.. Have one for me, and Ill do the same!!
I found the FA stamped on the top of my fathers differential just yesterday. I thought they only stamped the differential codes on the stamp plate on the bottom, so i was surprised to find the F and the A clearly stamped into the top.
n
Yep that and Jim Beam Black Label are good for sipping.
This question about the yokes if all that is different on the stub axles is how the u-joint is mounted what great benefit is it to change to the BB stub axles? Most of the failures that I have seen here and on the internet revolve around the half shaft failing not the stub axle.
I have seen what appears to be the trailing arm stub axle used as a differential stub and the half shaft have the same half shaft connection.
David
Received 1,857 Likes
David
David
Photo below shows what you may be talking about - Van Steel provided these flanged stub axles (and carbon fiber half-shafts) for the "King Ray" 572-powered '67 the late Jerry Clark built as a project car for "Corvette Enthusiast" magazine about six years ago.
I know this is a custom, but did Chevy ever put a white stinger on a '67 Sunfire Yellow/white interior BB hood? I can't remember seeing one like this, I seem to remember black stingers with that color combo.
