M22 with 4.7" bearing retainer
I'm putting a M22 (at least I believe it is) behind my DZ302 going in my 59 vette. I'm using a Lakewood scatter shield but when I tried to install the transmission I found that the bearing retainer was too big for the opening of the scatter shield. I measured the retainer and it was 4.7" across. I have other Muncies and they are about a half inch shorter across. also the bolts holding the retainer are further apart than my other muncies. I have several muncie trannys but I am not too knowledgeable about anything at all, seriously. So I had a person over that is knowledgeable and he's never seen a bearing retainer that wide for a Muncie. I just happened to have a bellhousing in my pile that had the larger opening, it fits into that one. Anyway, I couldn't find anything on line about any muncies having larger bearing retainers. so what is this?
Received 1,857 Likes
The 4.7" brg retainer is the std 64 and up Muncie / BW retainer size.
Sounds like you might have a bunch of '63 Munices with the small retainer diameter.
That Lakewood bell must be an odd-ball ('63 only applications ?)- that the 4.7" retainer won't fit.
Are you sure the retainer you are talking about isn't 5 1/8" diameter ?
