Oil Dipstick Tube Install External
Old 09-24-2012, 03:10 PM
54greg
Support Corvetteforum!
54greg's Avatar
Default Oil Dipstick Tube Install External
Installation into my 56 265 engine. I made a mess of the first one. Any suggestions before I install the second
Old 09-24-2012, 03:20 PM
Pilot Dan
Pilot Dan's Avatar
Many of the replacements I have come accross are too tight an initial fit and people try to pound them in and often bend or break them in the process. I like to take a little emery cloth and polish the portion on the tube that goes into the block so it can be lightly tapped in with a soft faced hammer. Pilot Dan
Old 09-24-2012, 04:06 PM
54greg
54greg's Avatar
Thank you
Old 09-24-2012, 11:50 PM
jtranger
jtranger's Avatar
Greg, I just did this on my '61. Emery cloth first, then put it in the freezer overnight. Heat up the hole in the block with a heatgun, lube the cold tube and it should go into place with some light persuasion.
Old 09-25-2012, 09:49 AM
54greg
54greg's Avatar
Perfect!
Old 09-25-2012, 11:51 AM
John McGraw
John McGraw's Avatar
The secret to installing the tube so it is not loose, is to make an installation tool. If you take a pipe nipple about 10" long, and cut half the nipple off longitudinally, for about 4" up the nipple, you will have a tool that will only bear on the flange at the bottom of the that sits on the block, and you can beat the hell out of it with a hammer, without worrying about damaging the tube. I wish I was at home, where I could take a pic of the tool that I made, but my description should suffice.
Regards, John McGraw
Old 09-25-2012, 11:58 AM
54greg
54greg's Avatar
Thanks John.
Size of pipe? 1/2" galvinized seems too big. Maybe 1/2' "red" copper?
Old 09-25-2012, 12:20 PM
John McGraw
My recollection was that it was 3/8, iron pipe, but it may be 1/4".
Measure the outside diameter of the tube, and that will tell you what size to use. Iron pipe is always sized by the ID of the pipe, so a 3/8 nipple will have a 3/8 ID. The tool I made, is a nice tight fit to the OD of the tube.
you will need to grind a slight slope on the end on the half-pipe, so that it will sit flat on top of the lip.
I will try to remember to pull it out of my tool box and take a pic of it tonight.
Old 09-25-2012, 12:23 PM
54greg
54greg's Avatar
Thanks again
To Oil Dipstick Tube Install External
Quick Reply: Oil Dipstick Tube Install External
