Power Steering Option
I read or was told that power steering was not avalible on a 365 H/P Vet. If so, was P/S avalible on 340,350 or 375 H/P Vets.
My 66 L79 (350hp) has power steering - also has A/C. I also read somewhere in the past about an issue with the 365hp and power steering but cannot located or remember the article. Someone on here has the right information!
Ron
Ron
Received 6,943 Likes
2015 C2 of Year Finalist
no power steering for the 365, and 375. they used a larger 5 quart oil pan that did not allow the PS relay rod
The 365 hp version had a six quart oil pan. Don't know about the F/I, but I assume the same. Other hp 327's had a standard five quart oil pan.
I thought it was 4 quarts in the pan a 1 quart oil filter for a total of a 5 quart system. The same with the solid lifter motors with a larger oil pan that held one more quart
That's correct - power steering wasn't available with either the 365hp or 375hp engines due to the 6-quart oil pan, and there was no way to order either one of those engines with a 5-quart pan.
Here's the post where JohnZ states the 365 had the 6 qt oil pan.
http://forums.corvetteforum.com/c1-a...hlight=oil+pan
I am just wondering if some one is confusing a total oil system volume verse just the oil pan volume. since I don't have any 65 GM books what do they say for capacity's
Possibly it's semantics, but the 365 oil pan has always been identified as the 6 quart oil pan as in this ad below. It doesn't really matter as long as you get the larger pan, and I think the original question as to why no power steering is offered on the 365 was answered either way. The oil pan was in the way.
http://www.google.com/url?sa=t&rct=j...5rI6PlCZbkj32A
Maybe we could just call it the oil pan for the 6 quart system.
Received 1,857 Likes
That's why I normally refer to them as the 5-quart (system) pan and the 6-quart (system) pan.
So we were all right.
