Rear axle lube 1960
Old 10-05-2012, 12:17 PM
Doug1964
Doug1964's Avatar
Default Rear axle lube 1960
Can I use any gl4 gl5 85w90 gear lube or do I have to use pure mineral oil 90 weight. I have a non posi rear diff. 1960 low hp 3.70 gears
Old 10-05-2012, 01:14 PM
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Yep, you're good with either one.
Tom Parsons
Old 10-05-2012, 03:49 PM
C1-Curt
C1-Curt's Avatar
What do you use in a 60 if you have a posi?
Old 10-05-2012, 04:12 PM
DZAUTO
DZAUTO's Avatar
Use a quality GL4 or 5 80w90 (85w90).
The MAJOR concensus of opinion for trannys such as the T10 or Muncie, should only be GL4. Thus GL4 is all I have. But since there is no brass in rearends, then GL5 is OK.
I buy GL4 in 5gal buckets because I build 4spds and rears.
Tom Parsons
Old 10-05-2012, 05:23 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Errr...Tom I think he's talking about the differential and the 'friction modifier' that the old posi units require. But I could be wrong of course.
Old 10-05-2012, 07:35 PM
capevettes
Support Corvetteforum!
capevettes's Avatar
Received 4,553 Likes on 2,160 Posts
2016 C2 of Year
2015 C3 of Year Finalist
I use 80/90 gear weight oil and one 4 oz bottle of GM posi lube in my 61 rear end with posi
Old 10-05-2012, 08:36 PM
DZAUTO
DZAUTO's Avatar
And you're absolutely correct. I thought he was just inquiring about the lube itself. So, yes, with 80w90 (85w90) gear oil in a posi, also add a bottle of GMs posi additive. MOST of the time one bottle of additive is sufficient, BUT on a few ocassions it may take 2 bottles if a posi is rebuilt with BOTH a pair of Belleville plates and a pair of Belleville discs.
Tom Parsons
To Rear axle lube 1960
Quick Reply: Rear axle lube 1960
