Any of you guys ever do a long distance ( 600 miles ) tow using a tow dolly instead of a full size trailer ? Problems, advice, Thanks
I flat towed a 1969 Camaro on a tow bar from South Florida to north of St. Louis once. About 1200 miles. I pulled the driveshaft before going.
It was a hassle in some parking lots during stops.
If you are towing a Corvette, you need to drop the driveshaft and tow it forward facing. It wasn't really intended to tow it backwards that far with the front wheels on the ground.
You will have issues with lights. The Camaro had a trunk, so a rack with lights could be strapped to the trunk lid and provide lights at the rear.
If you follow the rules completely, many of those U-Haul dollies are rated at 45 mph and towing faster is illegal, although it is rare to get stopped.
