58cc heads & flat top pistons ?
Dr. Detroit
Received 3,891 Likes
http://www.northernautoparts.com/Pro...tModelId=15094
I would not bother.....the 64/68 chamber flows so much better....especially when the chamber is relieved around the Intake Valve. The Tight chamber shrouds the valve.....and if I remember correctly has tiny Intake vales in it for the 283.
Jebby
Received 1,843 Likes
If you have the standard cam, those heads will be okay on a 327 up to about 4800 rpm. After that......................
Dr. Detroit
Jebby
Dr. Detroit
Jebby
St. Jude Donor '07
I was considering buying a pair of used aluminum aftermarket heads, 58cc chamber with 1.50 exh, 1.94 intake. Just needed to check the effect of the smaller chamber. The chart referenced was useful for compression. Thanks.
