Ignition shielding question
Does anyone have a picture of a 1960-62 engine with the shielding off? I'm trying to install ignition shielding and I'm having trouble with the right side bracket that holds the coil. It hits the dist and or the vacuum can and there isn't any room to adjust the timing. None of my books or catalogs show the bracket installed.
Thanks, Bob
Thanks, Bob
Received 1,859 Likes
Thanks, Bob
Thanks, Bob
Second photo isn't a Corvette, but it shows the correct distributor housing orientation and indexing of the wires in the cap with the engine properly timed.
Thanks for responding John. I do believe I have my distributor in correctly, it just seems as if there is not enough room for the bracket or I have the wrong bracket. I assume it bolts to the last bolt of the intake but I can't get it close enough because the coil part hits the dist cap. Thats why I was looking for an actual picture of the right hand bracket installed with the coil but without the top shield. The pics with the bracket hitting the dist is just laying there because there isn't room to get it down where it belongs.
Bob
Bob
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
It looks like it might be one tooth off on the drive gear. Pull the distributor out and look down the hole and you'll see the oil pump shaft with a slot in the top of it. The distributors drive gear pin slides down over it. Get a long screwdriver and rotate the pump shaft counterclock wise just a little and then reinsert the distributor. You'll feel it drop down over the shaft until it seats. This will move the advance closer to the carb and then the bracket should clear.
Here is a shot of my '61. My pertronix vacuum can is nearly hidden by the rotor but you can see how it's oriented.
When I was playing with my distributor, shielding etc a few years ago, what I remember is this: if the distributor is off one tooth in either direction, nothing fits and you won't be able to time it correctly. Visually trying to determine if the distributor is off by a tooth is extremely difficult.
Intake?
The area you are working in is pretty tight so getting the dizzy set get right critical. I noticed that you have an aftermarket intake and that maybe your problem. Only Corvettes have the shielding so that's probably not a design consideration for aftermarket intakes. If you can't get the advance to work at the "right" location simply clock it around to the driver's side like Franki did.
