'65 Holley to Edelbrock Carb Conversion
Hi all.... I have a 1965 327/350 hp with the stock Holley carb and frankly I am really getting fed up with the fuel leaks from all sorts of locations from the Holley. The latest leak is from the fuel supply banjo fitting on the front float bowl. I have looked at the Edelbrock Performer carb, 600 cfm, with the electric choke. I would like to use my stock '65 air cleaner. It appears to me that the breather tube is going to foul the Edelbrock carb body.
Has anyone converted their '65 350 or 365 hp engine from the Holley to the Edelbrock carb?
Alternatively any suggestions for getting the banjo fitting to seal without stripping the threads in the front bowl?
Received 1,857 Likes
This is a very bad idea. Just have the Holley rebuilt by someone who know what they are doing and it will be fine. If you insist on proceeding [which happens all too often] I hope that you will be wise enough to save all of the parts you remove so the next owner will happy no doubt to quickly put it back on the car.
Received 1,843 Likes
There's always the possibility of buying a new replacement Holley that hasn't been messed with to fix your problem.
I wouldn't go the AFB or Edelbrock route for reasons already mentioned.
I second this. I'm not one to slam Edelbrock or Carter carbs as they are fine carburetors for their own applications. But in this case you are better off having the Holley "restored" by a professional. This is far different than giving it to your favorite old mechanic to have a rebuild kit thrown in it. Send it to Holley to restore or some of the others - Bob Krutz I believe is (was?) another. I had my carb restored by Holley 20 years ago and except they put stock jets back in and I had to put my staggered jetting back, I haven't touched it since.
Received 2,127 Likes
If you take your time, pay attention to detail, understand the principals of it's operation you can have a very clean install with a very reliable carb. Enjoy the ride! Dennis
The following 2 users liked this post by Bluestripe67:
rtruman (10-22-2019),
toms silver 60 (10-21-2019)
I have no idea how my post got on this thread
Received 3,043 Likes
St. Jude Donor '05
Holley I think still refurbishes those. If not call Jeff at AED performance it will be perfect, bench tested etc.
I would have the carb rebuilt, there is nothing wrong with the Edelbrock carb. however as John Z stated there are several components unique to the 65/L79/L76 that will no longer operate as intended.
Received 5,554 Likes
Oh hell, just go with EFI at this point! Although it is more expensive, a Holley Sniper requires significantly less modifications at the engine end. In fact, everything will bolt right up. Now, the fuel tank end is a whole different story.
I’m not really serious, but I don’t consider an Edelbrock an upgrade to a Holley particularly if you have other performance upgrades. They are more sensitive to transition with low vacuum than a Holley and much more sensitive to higher fuel pressures, unable to tolerate much over 5 psi of fuel pressure without flooding. Be careful!
OP inquiry was 7 years ago. Only made one post and that was back then. Somebody check his garage and make sure he's not trapped under his car.
Damn I gotta start looking at the dates.
Probably the sneaky "Related Threads" listings at the bottom of the threads. It's probably good if you are searching a topic, otherwise it causes bizarre posts like this.
To turn it off:
USER CP
YOUR CONTROL PANEL
SETTINGS & OPTIONS
EDIT OPTIONS
THREAD DISPLAY OPTIONS
RELATED THREADS
Eric P (10-22-2019)
Received 1,518 Likes
C2 of Year Finalist (appearance mods) 2019
After messing with hundreds of carbs I can say that the Edelbrock will be down on power compared to a well prepared holley. I have had the best luck with Quick fuel Brawler series carb like a holley just better
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Look at Dates: Hell, we all need to look at the dates...Funny as hell!!!
Although, nothing wrong with historical information!!! LOL!
