Vingage AIr Install question ?
Looking for any pics of Vintage air installation on your 1967 L79
I heard that one should install the compressor and lines on the driver side rather then pass side because the removal of some a/c components is necessary to replace the battery ... has any one ran into this concern with the Gen IV Vintage air system ?
Thanx as always
csysman
Thanx as always
csysman
I installed mine on the passenger side. Changing the battery is tough. I did not have to disconnect the ac just pushed the lines to the side a picked up the battery
If you are using a period correct battery.You have turn the battery on it's end for removal.Not too big a problem with a sealed top.
Thanx as always
csysman
Thanx as always
csysman
On your question about putting the compressor and lines on the driver side on a 67, I don't think so, but you had better check with Vintage Air.
The manual says to remove the battery if on the passenger side, but I think only for access and installation of the evaporator and lines. At the end of the manual, it says to replace the removed parts, and I would assume that the battery goes back where it was on the passenger side. There are no instructions about relocating the battery.
Like I said above, I put in the older (not Gen IV) SureFit Series in my 67 327/300 and it was a snap with very few modifications to original parts, actually reused my original heater fan switch, and defroster cable.
The Gen IV system looks a lot more complicated with electron controls replacing the OEM. The glove box liner is changed, and you will also loose the passenger side vent and cable. Not sure about the driver side vent.
I think I would have re-thought putting in the system in 2004, had it been the current Gen IV. They had a great product then, why did they change it.
Jerry Fuccillo
Looks like just another add on a/c. Poor line routing etc..
Yes you cut down on the glove box size. But so what. I still keep papers and other non-essential items in there.
The system cleans up the passenger side of the firewall and now battery access is at least possible.
Oh and the system works like gangbusters with excellent cooling, heating, and all blending in between.
I really think that if God himself designed the system, many folks here would find something to complain about it.
I do and for the life of me I do not understand why folks aren't happy with the Gen IV system. Yes you do lose the passenger side vent but so what. It's just that, for the passenger, which in my case is the wifey, and she didn't even know it was there to begin with.
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
With the Gen IV, I found it very difficult to fit all 4 of the 2-1/2" vent hoses behind the radio where they exit the distribution box. Two of them have to make 180 degree turns as they exit the box. They pinch shut and no air comes through. I finally gave up, blocked off one of the hose connections at the box and the other 3 fit just fine. I lost air from the radio side panel vent on the passenger side but I have very cold air blowing out the other 3 vents which is more than enough.
Also, when the system was installed, the installer ran the heater hoses and the A/C hoses over top of the battery making the battery impossible to remove. Replacing the heater hoses with long hoses routed around the battery will be easy enough to do. I think the A/C hoses can just be pulled out of the way.
Overall, I like the system. It blows very cold air and that's what it's all about.
Thank u to those of you that replied ... i have a friend going to the SEMA Trade show Oct 30 and will give him a list of my concerns --- some of which have been listed here ... moving down to south Florida ... need the air if Im to enjoy the car .
much more enjoyable. I would suggest buying direct from VA.
Also suggest ordering the compressor with the rear exit lines,
because of the offset of the engine and the tight fit of the compressor
and the inner fender on the passenger side.
Just my experience with the install, but I know someone will
find an exceptation.
Tony
It's ugly inside and out and it cuts a basic factory installed function (fresh air). I use my fresh air vents often. The change in console side panels looks cheesy and the air duct running under the glove looks VERY aftermarket.
I do not consider the drivers side duct to be attractive and I found nothing wrong with it's location before..
I installed my own system. I wonder how many who complain of the old system actually installed their own?
As for the battery? No problems taking mine out. Last but not least. You don't need an electronic system in such a small car.I would not have purchased the Gen iv because of the above.
Just put a gen 4 in my `64 coupe this summer, It makes my car
Tony
Tony
The previous system had no problem cooling.
I opted not to do the rear exit lines.They make changing plugs much harder and cause interference in an already cluttered area.
IMHO the only vent that will look right above the clock is the factory design. The vent repro parts alone are about $400. Not to mention proper glasswork.
The C2 interior is so small the upper vent isn't really missed too much.First time around I wasn't ready for a job like that. But if I ever disassemble my dash again. I may add it.
Here's a link to the parts.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050i
2021 C1 of the Year Finalist - Unmodified
The Gen IV will never look even close to factory air on the interior.
Bob
You use the two hose outlets that normally connect to each console side panel (thats where the air comes out on the VA kit). And route them up to the center outlet.
The side vents are used for the heater/ac. VA system has plenty of fan cfm. You could probably create a splitter and keep the side panel heater/ac
I have been happy with the original vintage unit for over 100000 miles in my coupe for the last 15 years, but after installing the new gen 4 unit in my roadster it is like night and day, it is so much better in all aspects than the earlier unit.
The 2 problems are very easy to solve.
You do need to block off the rear lower exit duct because the bend is to tight to let air out. Then use a plastic y duct available from vintage and run 2 hoses from the y to the different sides along with the other 2 hoses keeping each in balance.
There is no need to lose the the right side vent, just use your old heater cover and run the heater hoses and refg. Lines out the blower motor hole.
The blend capabilities and variable fan speed of the new system is
awesome plus no mechanical cables to fool with.
Jeff
Jeff
